REST API reference
Delete an AKV configuration
Deletes an AKV configuration to remove its settings from the system. This operation is typically used when you no longer need the configuration and want to clean up the associated resources.
HTTP method and endpoint
DELETE /security/azure-key-vaults/{uuid}
Introduced in
ONTAP 9.8
  • security key-manager external azure disable
uuid
string
path
True
AKV UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536242
One or more self-encrypting drives are assigned an authentication key.
65536243
Cannot determine authentication key presence on one or more self-encrypting drives.
65536817
Internal error. Failed to determine if key manager is safe to disable.
65536827
Internal error. Failed to determine if the given SVM has any encrypted volumes.
65536834
Internal error. Failed to get existing key-server details for the given SVM.
65536867
Volume encryption keys (VEK) for one or more encrypted volumes are stored on the key manager configured for the given SVM.
65536883
Internal error. Volume encryption key is missing for a volume.
65536884
Internal error. Volume encryption key is invalid for a volume.
65536924
Cannot remove key manager that still contains one or more NSE authentication keys.
65537120
Azure Key Vault is not configured for the given SVM.
196608080
One or more nodes in the cluster have the root volume encrypted using NVE (NetApp Volume Encryption).
196608301
Internal error. Failed to get encryption type.
196608305
NAE aggregates found in the cluster.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
