Delete an AKV configuration
Deletes an AKV configuration to remove the association with your Azure Key Vault setup in ONTAP.
HTTP method and endpoint
DELETE /security/azure-key-vaults/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
security key-manager external azure disable
uuid |
string |
path |
True |
AKV UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536242 |
One or more self-encrypting drives are assigned an authentication key. |
65536243 |
Cannot determine authentication key presence on one or more self-encrypting drives. |
65536817 |
Internal error. Failed to determine if key manager is safe to disable. |
65536827 |
Internal error. Failed to determine if the given SVM has any encrypted volumes. |
65536834 |
Internal error. Failed to get existing key-server details for the given SVM. |
65536867 |
Volume encryption keys (VEK) for one or more encrypted volumes are stored on the key manager configured for the given SVM. |
65536883 |
Internal error. Volume encryption key is missing for a volume. |
65536884 |
Internal error. Volume encryption key is invalid for a volume. |
65536924 |
Cannot remove key manager that still contains one or more NSE authentication keys. |
65537120 |
Azure Key Vault is not configured for the given SVM. |
196608080 |
One or more nodes in the cluster have the root volume encrypted using NVE (NetApp Volume Encryption). |
196608301 |
Internal error. Failed to get encryption type. |
196608305 |
NAE aggregates found in the cluster. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
