REST API reference
Delete an AKV configuration
Removes an AKV configuration that is integrated with Azure NetApp Files Cloud Volume Services, disabling the external key manager setup for Azure.
HTTP method and endpoint
DELETE /security/azure-key-vaults/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Deletes an AKV configuration. Note: This method is only available to the Azure NetApp Files Cloud Volume Services.
  • security key-manager external azure disable
uuid
string
path
True
AKV UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536242
One or more Storage Encryption devices are assigned an authentication key.
65536817
Internal error. Failed to determine if key manager is safe to disable.
65536827
Internal error. Failed to determine if the given SVM has any encrypted volumes.
65536834
Internal error. Failed to get existing key-server details for the given SVM.
65536867
Volume encryption keys (VEK) for one or more encrypted volumes are stored on the key manager configured for the given SVM.
65536883
Internal error. Volume encryption key is missing for a volume.
65536884
Internal error. Volume encryption key is invalid for a volume.
65536924
Cannot remove key manager that still contains one or more NSE authentication keys.
65537120
Azure Key Vault is not configured for the given SVM.
196608080
One or more nodes in the cluster have the root volume encrypted using NVE (NetApp Volume Encryption).
196608301
Internal error. Failed to get encryption type.
196608305
NAE aggregates found in the cluster.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
