REST API reference
Retrieve CIFS servers
Retrieves information about CIFS servers to assess their configuration and status within your network environment. Use this endpoint when you need detailed insights for managing CIFS server settings or troubleshooting.
HTTP method and endpoint
GET /protocols/cifs/services
Introduced in
ONTAP 9.6
Usage notes
Retrieves CIFS servers.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • statistics.*
  • metric.*
  • vserver cifs server show
  • vserver cifs server options show
  • vserver cifs server security show
metric.latency.total
integer
query
False
Filter by metric.latency.total
  • Introduced in: 9.7
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.status
string
query
False
Filter by metric.status
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.duration
string
query
False
Filter by metric.duration
default_unix_user
string
query
False
Filter by default_unix_user
enabled
boolean
query
False
Filter by enabled
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 0
group_policy_object_enabled
boolean
query
False
Filter by group_policy_object_enabled
  • Introduced in: 9.12
ad_domain.organizational_unit
string
query
False
Filter by ad_domain.organizational_unit
ad_domain.default_site
string
query
False
Filter by ad_domain.default_site
  • Introduced in: 9.13
ad_domain.fqdn
string
query
False
Filter by ad_domain.fqdn
netbios.enabled
boolean
query
False
Filter by netbios.enabled
netbios.aliases
string
query
False
Filter by netbios.aliases
  • maxLength: 15
  • minLength: 1
netbios.wins_servers
string
query
False
Filter by netbios.wins_servers
name
string
query
False
Filter by name
  • maxLength: 15
  • minLength: 1
options.export_policy_enabled
boolean
query
False
Filter by options.export_policy_enabled
options.advanced_sparse_file
boolean
query
False
Filter by options.advanced_sparse_file
  • Introduced in: 9.10
options.large_mtu
boolean
query
False
Filter by options.large_mtu
options.shadowcopy_dir_depth
integer
query
False
Filter by options.shadowcopy_dir_depth
  • Introduced in: 9.11
options.path_component_cache
boolean
query
False
Filter by options.path_component_cache
options.fake_open
boolean
query
False
Filter by options.fake_open
options.copy_offload
boolean
query
False
Filter by options.copy_offload
options.multichannel
boolean
query
False
Filter by options.multichannel
options.admin_to_root_mapping
boolean
query
False
Filter by options.admin_to_root_mapping
options.widelink_reparse_versions
string
query
False
Filter by options.widelink_reparse_versions
options.smb_credits
integer
query
False
Filter by options.smb_credits
  • Max value: 8192
  • Min value: 2
options.referral
boolean
query
False
Filter by options.referral
options.shadowcopy
boolean
query
False
options.fsctl_trim
boolean
query
False
Filter by options.fsctl_trim
options.junction_reparse
boolean
query
False
Filter by options.junction_reparse
options.null_user_windows_name
string
query
False
Filter by options.null_user_windows_name
security.aes_netlogon_enabled
boolean
query
False
Filter by security.aes_netlogon_enabled
security.session_security
string
query
False
Filter by security.session_security
security.smb_signing
boolean
query
False
Filter by security.smb_signing
security.encrypt_dc_connection
boolean
query
False
Filter by security.encrypt_dc_connection
  • Introduced in: 9.8
security.use_ldaps
boolean
query
False
Filter by security.use_ldaps
security.restrict_anonymous
string
query
False
Filter by security.restrict_anonymous
security.lm_compatibility_level
string
query
False
Filter by security.lm_compatibility_level
security.kdc_encryption
boolean
query
False
Filter by security.kdc_encryption
security.advertised_kdc_encryptions
string
query
False
Filter by security.advertised_kdc_encryptions
security.smb_encryption
boolean
query
False
Filter by security.smb_encryption
security.use_start_tls
boolean
query
False
Filter by security.use_start_tls
security.ldap_referral_enabled
boolean
query
False
Filter by security.ldap_referral_enabled
security.try_ldap_channel_binding
boolean
query
False
Filter by security.try_ldap_channel_binding
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.status
string
query
False
Filter by statistics.status
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_service]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ad_domain": {
        "default_site": "string",
        "fqdn": "example.com",
        "organizational_unit": "string"
      "comment": "This CIFS Server Belongs to CS Department",
      "default_unix_user": "string",
      "metric": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 06:20:13 -0500"
      "name": "CIFS1",
      "netbios": {
        "aliases": [
          "ALIAS_1",
          "ALIAS_2",
          "ALIAS_3"
        "wins_servers": [
          "10.224.65.20",
          "10.224.65.21"
      "options": {
        "null_user_windows_name": "string",
        "smb_credits": 128,
        "widelink_reparse_versions": [
          "smb1"
      "security": {
        "advertised_kdc_encryptions": [
          "string"
        "lm_compatibility_level": "string",
        "restrict_anonymous": "string",
        "session_security": "string"
      "statistics": {
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ad_domain
default_site
string
The default site used by LIFs that do not have a site membership.
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
cifs_netbios
aliases
array[string]
enabled
boolean
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration.
wins_servers
array[string]
cifs_service_options
boolean
Specifies whether or not Administrator can be mapped to the UNIX user "root".
boolean
Specifies whether or not the CIFS server supports the advanced sparse file capabilities. This allows CIFS clients to query the allocated ranges of a file and to write zeroes or free data blocks for ranges of a file.
copy_offload
boolean
Specifies whether or not to enable the Copy Offload feature. This feature enables direct data transfers within or between compatible storage devices without transferring the data through the host computer.
Note that this will also enable/disable the direct copy feature accordingly.
boolean
Specifies whether or not export policies are enabled for CIFS.
fake_open
boolean
Specifies whether or not fake open support is enabled. This parameter allows you to optimize the open and close requests coming from SMB 2 clients.
fsctl_trim
boolean
Specifies whether or not the trim requests (FSCTL_FILE_LEVEL_TRIM) are supported on the CIFS server.
junction_reparse
boolean
Specifies whether or not the reparse point support is enabled. When enabled the CIFS server exposes junction points to Windows clients as reparse points. This parameter is only active if the client has negotiated use of the SMB 2 or SMB 3 protocol. This parameter is not supported for SVMs with Infinite Volume.
large_mtu
boolean
Specifies whether or not SMB clients can send reads up to 1 MB in size.
multichannel
boolean
Specifies whether or not the CIFS server supports Multichannel.
string
Specifies a Windows User or Group name that should be mapped in case of a NULL user value.
boolean
Specifies whether or not the path component cache is enabled on the CIFS server.
referral
boolean
Specifies whether or not to refer clients to more optimal LIFs. When enabled, it automatically refers clients to a data LIF local to the node which hosts the root of the requested share.
shadowcopy
boolean
Specifies whether or not to enable the Shadowcopy Feature. This feature enables to take share-based backup copies of data that is in a data-consistent state at a specific point in time where the data is accessed over SMB 3.0 shares.
integer
Specifies the maximum level of subdirectories on which ONTAP should create shadow copies.
  • Default value: 5
  • x-nullable: true
smb_credits
integer
Specifies the maximum number of outstanding requests on a CIFS connection.
array[string]
Specifies the CIFS protocol versions for which the widelink is reported as reparse point.
cifs_service_security
array[string]
boolean
Specifies whether or not an AES session key is enabled for the Netlogon channel.
boolean
Specifies whether encryption is required for domain controller connections.
kdc_encryption
boolean
Important This attribute has been deprecated. Use "security.advertised_kdc_encryptions" to specify the encryption type to use. Specifies whether AES-128 and AES-256 encryption is enabled for all Kerberos-based communication with the Active Directory KDC. To take advantage of the strongest security with Kerberos-based communication, AES-256 and AES-128 encryption can be enabled on the CIFS server. Kerberos-related communication for CIFS is used during CIFS server creation on the SVM, as well as during the SMB session setup phase. The CIFS server supports the following encryption types for Kerberos communication:
  • RC4-HMAC
  • DES
  • AES When the CIFS server is created, the domain controller creates a computer machine account in Active Directory. After a newly created machine account authenticates, the KDC and the CIFS server negotiates encryption types. At this time, the KDC becomes aware of the encryption capabilities of the particular machine account and uses those capabilities in subsequent communication with the CIFS server. In addition to negotiating encryption types during CIFS server creation, the encryption types are renegotiated when a machine account password is reset.
boolean
Specifies whether or not LDAP referral chasing is enabled for AD LDAP connections.
string
It is CIFS server minimum security level, also known as the LMCompatibilityLevel. The minimum security level is the minimum level of the security tokens that the CIFS server accepts from SMB clients. The available values are:
  • lm_ntlm_ntlmv2_krb Accepts LM, NTLM, NTLMv2 and Kerberos
  • ntlm_ntlmv2_krb Accepts NTLM, NTLMv2 and Kerberos
  • ntlmv2_krb Accepts NTLMv2 and Kerberos
  • krb Accepts Kerberos only
restrict_anonymous
string
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
  • no_restriction - No access restriction for an anonymous user.
  • no_enumeration - Enumeration is restricted for an anonymous user.
  • no_access - All access is restricted for an anonymous user.
session_security
string
Specifies client session security for AD LDAP connections. The available values are:
  • none - No Signing or Sealing.
  • sign - Sign LDAP traffic.
  • seal - Seal and Sign LDAP traffic
smb_encryption
boolean
Specifies whether encryption is required for incoming CIFS traffic.
smb_signing
boolean
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised.
boolean
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS.
use_ldaps
boolean
Specifies whether or not to use use LDAPS for secure Active Directory LDAP connections by using the TLS/SSL protocols.
use_start_tls
boolean
Specifies whether or not to use SSL/TLS for allowing secure LDAP communication with Active Directory LDAP servers.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
_links
_links
name
string
uuid
string
cifs_service
_links
_links
ad_domain
ad_domain
comment
string
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks.
default_unix_user
string
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails.
enabled
boolean
Specifies if the CIFS service is administratively enabled.
boolean
If set to true, group policies will be applied to the SVM.
metric
metric
name
string
The name of the CIFS server.
netbios
cifs_netbios
options
security
statistics
statistics
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
