Retrieve CIFS servers
GET /protocols/cifs/services
Retrieves CIFS servers.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
vserver cifs server show -
vserver cifs server options show -
vserver cifs server security show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
default_unix_user |
string |
query |
False |
Filter by default_unix_user |
enabled |
boolean |
query |
False |
Filter by enabled |
name |
string |
query |
False |
Filter by name |
security.kdc_encryption |
boolean |
query |
False |
Filter by security.kdc_encryption |
security.restrict_anonymous |
string |
query |
False |
Filter by security.restrict_anonymous |
security.smb_encryption |
boolean |
query |
False |
Filter by security.smb_encryption |
security.smb_signing |
boolean |
query |
False |
Filter by security.smb_signing |
netbios.wins_servers |
string |
query |
False |
Filter by netbios.wins_servers |
netbios.enabled |
boolean |
query |
False |
Filter by netbios.enabled |
netbios.aliases |
string |
query |
False |
Filter by netbios.aliases |
metric.duration |
string |
query |
False |
Filter by metric.duration |
metric.latency.other |
integer |
query |
False |
Filter by metric.latency.other |
metric.latency.write |
integer |
query |
False |
Filter by metric.latency.write |
metric.latency.read |
integer |
query |
False |
Filter by metric.latency.read |
metric.latency.total |
integer |
query |
False |
Filter by metric.latency.total |
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read |
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write |
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total |
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp |
metric.iops.other |
integer |
query |
False |
Filter by metric.iops.other |
metric.iops.write |
integer |
query |
False |
Filter by metric.iops.write |
metric.iops.read |
integer |
query |
False |
Filter by metric.iops.read |
metric.iops.total |
integer |
query |
False |
Filter by metric.iops.total |
metric.status |
string |
query |
False |
Filter by metric.status |
statistics.status |
string |
query |
False |
Filter by statistics.status |
statistics.latency_raw.other |
integer |
query |
False |
Filter by statistics.latency_raw.other |
statistics.latency_raw.write |
integer |
query |
False |
Filter by statistics.latency_raw.write |
statistics.latency_raw.read |
integer |
query |
False |
Filter by statistics.latency_raw.read |
statistics.latency_raw.total |
integer |
query |
False |
Filter by statistics.latency_raw.total |
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp |
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read |
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write |
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total |
statistics.iops_raw.other |
integer |
query |
False |
Filter by statistics.iops_raw.other |
statistics.iops_raw.write |
integer |
query |
False |
Filter by statistics.iops_raw.write |
statistics.iops_raw.read |
integer |
query |
False |
Filter by statistics.iops_raw.read |
statistics.iops_raw.total |
integer |
query |
False |
Filter by statistics.iops_raw.total |
ad_domain.fqdn |
string |
query |
False |
Filter by ad_domain.fqdn |
ad_domain.organizational_unit |
string |
query |
False |
Filter by ad_domain.organizational_unit |
ad_domain.user |
string |
query |
False |
Filter by ad_domain.user |
comment |
string |
query |
False |
Filter by comment |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cifs_service] |
"next": {
"href": "/api/resourcelink"
"records": [
"ad_domain": {
"fqdn": "example.com",
"organizational_unit": "string",
"user": "string"
"comment": "This CIFS Server Belongs to CS Department",
"default_unix_user": "string",
"metric": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 UTC"
"name": "CIFS1",
"netbios": {
"aliases": [
"ALIAS_1",
"ALIAS_2",
"ALIAS_3"
"wins_servers": [
"10.224.65.20",
"10.224.65.21"
"security": {
"restrict_anonymous": "string"
"statistics": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ad_domain
fqdn |
string |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only. |
string |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only. |
user |
string |
The user account used to add this CIFS server to the Active Directory. POST and DELETE only. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
cifs_netbios
aliases |
array[string] |
enabled |
boolean |
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration. |
wins_servers |
array[string] |
cifs_service_security
kdc_encryption |
boolean |
Specifies whether AES-128 and AES-256 encryption is enabled for all Kerberos-based communication with the Active Directory KDC. To take advantage of the strongest security with Kerberos-based communication, AES-256 and AES-128 encryption can be enabled on the CIFS server. Kerberos-related communication for CIFS is used during CIFS server creation on the SVM, as well as during the SMB session setup phase. The CIFS server supports the following encryption types for Kerberos communication:
string |
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
smb_encryption |
boolean |
Specifies whether encryption is required for incoming CIFS traffic. |
smb_signing |
boolean |
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cifs_service
_links |
ad_domain |
comment |
string |
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks. |
default_unix_user |
string |
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails. |
enabled |
boolean |
Specifies if the CIFS service is administratively enabled. |
metric |
name |
string |
The name of the CIFS server. |
netbios |
security |
statistics |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
