REST API reference
Retrieve CIFS servers
Retrieves CIFS server information to understand the configuration and status of your CIFS servers within the ONTAP environment.
HTTP method and endpoint
GET /protocols/cifs/services
Introduced in
ONTAP 9.6
Usage notes
Retrieves CIFS servers.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • statistics.*
  • metric.*
  • vserver cifs server show
  • vserver cifs server options show
  • vserver cifs server security show
auth-style
string
query
False
Filter by auth-style
  • Introduced in: 9.15
timeout
integer
query
False
Filter by timeout
key_vault_uri
string
query
False
Filter by key_vault_uri
tenant_id
string
query
False
Filter by tenant_id
proxy_type
string
query
False
Filter by proxy_type
security.encrypt_dc_connection
boolean
query
False
Filter by security.encrypt_dc_connection
  • Introduced in: 9.8
security.restrict_anonymous
string
query
False
Filter by security.restrict_anonymous
security.smb_encryption
boolean
query
False
Filter by security.smb_encryption
security.lm_compatibility_level
string
query
False
Filter by security.lm_compatibility_level
security.aes_netlogon_enabled
boolean
query
False
Filter by security.aes_netlogon_enabled
  • Introduced in: 9.10
security.smb_signing
boolean
query
False
Filter by security.smb_signing
security.use_start_tls
boolean
query
False
Filter by security.use_start_tls
security.kdc_encryption
boolean
query
False
Filter by security.kdc_encryption
security.session_security
string
query
False
Filter by security.session_security
security.ldap_referral_enabled
boolean
query
False
Filter by security.ldap_referral_enabled
security.use_ldaps
boolean
query
False
Filter by security.use_ldaps
security.try_ldap_channel_binding
boolean
query
False
Filter by security.try_ldap_channel_binding
security.advertised_kdc_encryptions
string
query
False
Filter by security.advertised_kdc_encryptions
  • Introduced in: 9.12
oauth_host
string
query
False
Filter by oauth_host
metric.duration
string
query
False
Filter by metric.duration
  • Introduced in: 9.7
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.status
string
query
False
Filter by metric.status
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.write
integer
query
False
Filter by metric.iops.write
proxy_port
integer
query
False
Filter by proxy_port
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.status
string
query
False
Filter by statistics.status
default_unix_user
string
query
False
Filter by default_unix_user
proxy_username
string
query
False
Filter by proxy_username
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 0
verify_host
boolean
query
False
Filter by verify_host
proxy_host
string
query
False
Filter by proxy_host
options.export_policy_enabled
boolean
query
False
Filter by options.export_policy_enabled
  • Introduced in: 9.13
options.fsctl_trim
boolean
query
False
Filter by options.fsctl_trim
options.advanced_sparse_file
boolean
query
False
Filter by options.advanced_sparse_file
options.null_user_windows_name
string
query
False
Filter by options.null_user_windows_name
options.dac_enabled
boolean
query
False
Filter by options.dac_enabled
options.smb_credits
integer
query
False
Filter by options.smb_credits
  • Max value: 8192
  • Min value: 2
options.client_version_reporting_enabled
boolean
query
False
Filter by options.client_version_reporting_enabled
  • Introduced in: 9.16
options.widelink_reparse_versions
string
query
False
Filter by options.widelink_reparse_versions
options.multichannel
boolean
query
False
Filter by options.multichannel
options.referral
boolean
query
False
Filter by options.referral
options.shadowcopy
boolean
query
False
Filter by options.shadowcopy
  • Introduced in: 9.11
options.fake_open
boolean
query
False
Filter by options.fake_open
options.max_same_tree_connect_per_session
integer
query
False
Filter by options.max_same_tree_connect_per_session
options.max_same_user_sessions_per_connection
integer
query
False
Filter by options.max_same_user_sessions_per_connection
options.max_watches_set_per_tree
integer
query
False
Filter by options.max_watches_set_per_tree
options.path_component_cache
boolean
query
False
Filter by options.path_component_cache
options.admin_to_root_mapping
boolean
query
False
Filter by options.admin_to_root_mapping
options.max_opens_same_file_per_tree
integer
query
False
Filter by options.max_opens_same_file_per_tree
options.max_connections_per_session
integer
query
False
Filter by options.max_connections_per_session
  • Max value: 1024
  • Min value: 2
options.shadowcopy_dir_depth
integer
query
False
Filter by options.shadowcopy_dir_depth
options.trusted_domain_enum_search_enabled
boolean
query
False
Filter by options.trusted_domain_enum_search_enabled
options.large_mtu
boolean
query
False
Filter by options.large_mtu
options.copy_offload
boolean
query
False
Filter by options.copy_offload
options.max_lifs_per_session
integer
query
False
Filter by options.max_lifs_per_session
  • Max value: 256
  • Min value: 1
options.client_dup_detection_enabled
boolean
query
False
Filter by options.client_dup_detection_enabled
options.junction_reparse
boolean
query
False
Filter by options.junction_reparse
options.backup_symlink_enabled
boolean
query
False
Filter by options.backup_symlink_enabled
group_policy_object_enabled
boolean
query
False
Filter by group_policy_object_enabled
enabled
boolean
query
False
Filter by enabled
ad_domain.fqdn
string
query
False
Filter by ad_domain.fqdn
ad_domain.organizational_unit
string
query
False
Filter by ad_domain.organizational_unit
ad_domain.default_site
string
query
False
Filter by ad_domain.default_site
auth_user_type
string
query
False
Filter by auth_user_type
netbios.wins_servers
string
query
False
Filter by netbios.wins_servers
netbios.aliases
string
query
False
Filter by netbios.aliases
  • maxLength: 15
  • minLength: 1
netbios.enabled
boolean
query
False
Filter by netbios.enabled
authentication_method
string
query
False
Filter by authentication_method
client_id
string
query
False
Filter by client_id
name
string
query
False
Filter by name
  • maxLength: 15
  • minLength: 1
workgroup
string
query
False
Filter by workgroup
  • maxLength: 15
  • minLength: 1
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
azure_cloud_region
string
query
False
Filter by azure_cloud_region
  • Introduced in: 9.19
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_service]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ad_domain": {
        "default_site": "string",
        "fqdn": "example.com",
        "organizational_unit": "string"
      "auth-style": "domain",
      "auth_user_type": "string",
      "authentication_method": "string",
      "azure_cloud_region": "string",
      "client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
      "comment": "This CIFS Server Belongs to CS Department",
      "default_unix_user": "string",
      "key_vault_uri": "https://kmip-akv-keyvault.vault.azure.net/",
      "metric": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 11:20:13 +0000"
      "name": "CIFS1",
      "netbios": {
        "aliases": [
          "ALIAS_1",
          "ALIAS_2",
          "ALIAS_3"
        "wins_servers": [
          "10.224.65.20",
          "10.224.65.21"
      "oauth_host": "login.microsoftonline.com",
      "options": {
        "max_connections_per_session": 32,
        "max_lifs_per_session": 256,
        "max_opens_same_file_per_tree": 1000,
        "max_same_tree_connect_per_session": 5000,
        "max_same_user_sessions_per_connection": 2500,
        "max_watches_set_per_tree": 500,
        "null_user_windows_name": "string",
        "smb_credits": 128,
        "widelink_reparse_versions": [
          "smb1"
      "proxy_host": "proxy.eng.com",
      "proxy_port": 1234,
      "proxy_type": "string",
      "proxy_username": "proxyuser",
      "security": {
        "advertised_kdc_encryptions": [
          "string"
        "lm_compatibility_level": "string",
        "restrict_anonymous": "string",
        "session_security": "string"
      "statistics": {
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "svm": {
        "name": "svm1",
      "tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
      "timeout": 25,
      "workgroup": "workgrp1"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ad_domain
default_site
string
The default site used by LIFs that do not have a site membership.
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
cifs_netbios
aliases
array[string]
enabled
boolean
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration.
wins_servers
array[string]
cifs_service_options
boolean
Specifies whether or not Administrator can be mapped to the UNIX user "root".
boolean
Specifies whether or not the CIFS server supports the advanced sparse file capabilities. This allows CIFS clients to query the allocated ranges of a file and to write zeroes or free data blocks for ranges of a file.
boolean
Specifies whether or not to preserve UNIX symlinks during backup through SMB.
boolean
Specifies whether or not client duplicate session detection is enabled for CIFS.
boolean
Specifies whether or not client version reporting is enabled for CIFS.
copy_offload
boolean
Specifies whether or not to enable the Copy Offload feature. This feature enables direct data transfers within or between compatible storage devices without transferring the data through the host computer.
Note that this will also enable/disable the direct copy feature accordingly.
dac_enabled
boolean
Specifies whether or not the Dynamic Access Control (DAC) feature is enabled for the CIFS server.
boolean
Specifies whether or not export policies are enabled for CIFS.
fake_open
boolean
Specifies whether or not fake open support is enabled. This parameter allows you to optimize the open and close requests coming from SMB 2 clients.
fsctl_trim
boolean
Specifies whether or not the trim requests (FSCTL_FILE_LEVEL_TRIM) are supported on the CIFS server.
junction_reparse
boolean
Specifies whether or not the reparse point support is enabled. When enabled the CIFS server exposes junction points to Windows clients as reparse points. This parameter is only active if the client has negotiated use of the SMB 2 or SMB 3 protocol. This parameter is not supported for SVMs with Infinite Volume.
large_mtu
boolean
Specifies whether or not SMB clients can send reads up to 1 MB in size.
integer
Specifies the maximum number of connections allowed per multichannel session.
integer
Specifies the maximum number of LIFs advertised per multichannel session.
integer
Specifies the maximum number of opens on the same file per tree.
integer
Specifies the maximum number of same tree connections per session.
integer
Specifies the maximum number of same user sessions per connection.
integer
Specifies the maximum number of watches set per tree.
multichannel
boolean
Specifies whether or not the CIFS server supports Multichannel.
string
Specifies a Windows User or Group name that should be mapped in case of a NULL user value.
boolean
Specifies whether or not the path component cache is enabled on the CIFS server.
referral
boolean
Specifies whether or not to refer clients to more optimal LIFs. When enabled, it automatically refers clients to a data LIF local to the node which hosts the root of the requested share.
shadowcopy
boolean
Specifies whether or not to enable the Shadowcopy Feature. This feature enables to take share-based backup copies of data that is in a data-consistent state at a specific point in time where the data is accessed over SMB 3.0 shares.
integer
Specifies the maximum level of subdirectories on which ONTAP should create shadow copies.
  • Default value: 5
  • x-nullable: true
smb_credits
integer
Specifies the maximum number of outstanding requests on a CIFS connection.
boolean
Specifies whether or not to enable trusted domain search.
  • If this parameter is set to true, it displays CIFS options only for CIFS servers that support enumeration of bidirectional trusted domains and that support searching in all bidirectional trusted domains when performing Windows user lookups for UNIX user to Windows user name mapping.
  • If set to false, it displays CIFS options for CIFS servers that do not support enumeration of bidirectional trusted domains.
array[string]
Specifies the CIFS protocol versions for which the widelink is reported as reparse point.
cifs_service_security
array[string]
boolean
Specifies whether or not an AES session key is enabled for the Netlogon channel.
boolean
Specifies whether encryption is required for domain controller connections.
kdc_encryption
boolean
Important This attribute has been deprecated. Use "security.advertised_kdc_encryptions" to specify the encryption type to use. Specifies whether AES-128 and AES-256 encryption is enabled for all Kerberos-based communication with the Active Directory KDC. To take advantage of the strongest security with Kerberos-based communication, AES-256 and AES-128 encryption can be enabled on the CIFS server. Kerberos-related communication for CIFS is used during CIFS server creation on the SVM, as well as during the SMB session setup phase. The CIFS server supports the following encryption types for Kerberos communication:
  • RC4-HMAC
  • DES
  • AES When the CIFS server is created, the domain controller creates a computer machine account in Active Directory. After a newly created machine account authenticates, the KDC and the CIFS server negotiates encryption types. At this time, the KDC becomes aware of the encryption capabilities of the particular machine account and uses those capabilities in subsequent communication with the CIFS server. In addition to negotiating encryption types during CIFS server creation, the encryption types are renegotiated when a machine account password is reset.
boolean
Specifies whether or not LDAP referral chasing is enabled for AD LDAP connections.
string
It is CIFS server minimum security level, also known as the LMCompatibilityLevel. The minimum security level is the minimum level of the security tokens that the CIFS server accepts from SMB clients. The available values are:
  • lm_ntlm_ntlmv2_krb Accepts LM, NTLM, NTLMv2 and Kerberos
  • ntlm_ntlmv2_krb Accepts NTLM, NTLMv2 and Kerberos
  • ntlmv2_krb Accepts NTLMv2 and Kerberos
  • krb Accepts Kerberos only
restrict_anonymous
string
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
  • no_restriction - No access restriction for an anonymous user.
  • no_enumeration - Enumeration is restricted for an anonymous user.
  • no_access - All access is restricted for an anonymous user.
session_security
string
Specifies client session security for AD LDAP connections. The available values are:
  • none - No Signing or Sealing.
  • sign - Sign LDAP traffic.
  • seal - Seal and Sign LDAP traffic
smb_encryption
boolean
Specifies whether encryption is required for incoming CIFS traffic.
smb_signing
boolean
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised.
boolean
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS.
use_ldaps
boolean
Specifies whether or not to use use LDAPS for secure Active Directory LDAP connections by using the TLS/SSL protocols.
use_start_tls
boolean
Specifies whether or not to use SSL/TLS for allowing secure LDAP communication with Active Directory LDAP servers.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
_links
_links
name
string
uuid
string
cifs_service
_links
_links
ad_domain
ad_domain
auth-style
string
Authentication type.
auth_user_type
string
Specifies the type of user who can access the SMB Volume. The default is domain_user. In the case of a hybrid-user, ONTAP won't contact on-premise ADDS.
  • enum: ["domain_user", "hybrid_user"]
  • x-nullable: true
string
Specifies the authentication method. The available values are:
  • client_secret
  • certificate
azure_cloud_region
string
Specifies the azure cloud location of the tenant in case of hybrid-user authentication
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId.
comment
string
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks.
default_unix_user
string
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails.
enabled
boolean
Specifies if the CIFS service is administratively enabled.
boolean
If set to true, group policies will be applied to the SVM.
key_vault_uri
string
URI of the deployed AKV that is used by ONTAP for storing keys.
metric
metric
name
string
The name of the CIFS server.
netbios
cifs_netbios
oauth_host
string
Open authorization server host name.
options
proxy_host
string
Proxy host.
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
security
statistics
statistics
svm
svm
tenant_id
string
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId.
timeout
integer
AKV connection timeout, in seconds. The allowed range is between 0 to 30 seconds.
verify_host
boolean
Verify the identity of the AKV host name. By default, verify_host is set to true.
workgroup
string
The workgroup name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
