Retrieve all S3 lifecycle rules for a bucket
Retrieves all S3 lifecycle rules associated with a bucket, which is useful for managing and reviewing the lifecycle policies applied to your data objects.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules/{name}
Introduced in
ONTAP 9.13
Usage notes
Note that in order to retrieve S3 bucket rule parametes, the 'fields' option should be set to '**'.
Related ONTAP commands
vserver object-store-server bucket lifecycle-management-rule show
s3_bucket.uuid |
string |
path |
True |
The unique identifier of the bucket. |
name |
string |
path |
True |
The name of the lifecycle management rule to be applied on the bucket. |
svm.uuid |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
abort_incomplete_multipart_upload |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags. |
bucket_name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
enabled |
boolean |
Specifies whether or not the associated rule is enabled. |
expiration |
Specifies a way to perform expiration action on filtered objects within a bucket. |
name |
string |
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters. |
non_current_version_expiration |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket. |
object_filter |
Specifies a way to filter objects within a bucket. |
svm |
Specifies the name of the SVM where this bucket exists. |
uuid |
string |
Specifies the unique identifier of the bucket. |
"href": "/api/resourcelink"
"abort_incomplete_multipart_upload": {
"bucket_name": "bucket1",
"expiration": {
"object_expiry_date": "string"
"name": "string",
"non_current_version_expiration": {
"object_filter": {
"prefix": "/logs",
"size_greater_than": 10240,
"size_less_than": 10485760,
"tags": [
"project1=projA",
"project2=projB"
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
_links |
after_initiation_days |
integer |
Number of days of initiation after which uploads can be aborted. |
expiration
_links |
expired_object_delete_marker |
boolean |
Cleanup object delete markers. |
object_age_days |
integer |
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date. |
object_expiry_date |
string |
Specific date from when objects can expire. This cannot be used with object_age_days. |
_links |
new_non_current_versions |
integer |
Number of latest non-current versions to be retained. |
non_current_days |
integer |
Number of days after which non-current versions can be deleted. |
object_filter
_links |
prefix |
string |
A prefix that is matched against object-names within a bucket. |
size_greater_than |
integer |
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied. |
size_less_than |
integer |
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied. |
tags |
array[string] |
An array of key-value paired tags of the form |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
