Retrieve all S3 lifecycle rules for a bucket
Retrieves all S3 lifecycle rules for a bucket to understand the rules associated with managing the lifecycle of objects within the bucket. This can help you ensure that objects are stored and deleted according to your specified policies.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules/{name}
Introduced in
ONTAP 9.13
Usage notes
Retrieves all S3 Lifecycle rules associated with a bucket. Note that in order to retrieve S3 bucket rule parameters, the 'fields' option should be set to '**'.
Related ONTAP commands
vserver object-store-server bucket lifecycle-management-rule show
s3_bucket.uuid |
string |
path |
True |
The unique identifier of the bucket. |
name |
string |
path |
True |
The name of the lifecycle management rule to be applied on the bucket. |
svm.uuid |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
abort_incomplete_multipart_upload |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags. |
bucket_name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
enabled |
boolean |
Specifies whether or not the associated rule is enabled. |
expiration |
Specifies a way to perform expiration action on filtered objects within a bucket. |
name |
string |
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters. |
non_current_version_expiration |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket. |
object_filter |
Specifies a way to filter objects within a bucket. |
svm |
Specifies the name of the SVM where this bucket exists. |
uuid |
string |
Specifies the unique identifier of the bucket. |
"href": "/api/resourcelink"
"abort_incomplete_multipart_upload": {
"bucket_name": "bucket1",
"expiration": {
"object_age_days": 100,
"object_expiry_date": "2039-09-22 20:00:00 -0400"
"name": "string",
"non_current_version_expiration": {
"object_filter": {
"prefix": "/logs",
"size_greater_than": 10240,
"size_less_than": 10485760,
"tags": [
"project1=projA",
"project2=projB"
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
_links |
after_initiation_days |
integer |
Number of days of initiation after which uploads can be aborted. |
expiration
_links |
expired_object_delete_marker |
boolean |
Cleanup object delete markers. |
object_age_days |
integer |
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date. |
object_expiry_date |
string |
Specific date from when objects can expire. This cannot be used with object_age_days. |
_links |
new_non_current_versions |
integer |
Number of latest non-current versions to be retained. |
non_current_days |
integer |
Number of days after which non-current versions can be deleted. |
object_filter
_links |
prefix |
string |
A prefix that is matched against object-names within a bucket. |
size_greater_than |
integer |
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied. |
size_less_than |
integer |
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied. |
tags |
array[string] |
An array of key-value paired tags of the form |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
