REST API reference
Retrieve all S3 lifecycle rules for a bucket
Retrieves all S3 lifecycle rules for a bucket to understand the rules associated with managing the lifecycle of objects within the bucket. This can help you ensure that objects are stored and deleted according to your specified policies.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules/{name}
Introduced in
ONTAP 9.13
Usage notes
Retrieves all S3 Lifecycle rules associated with a bucket. Note that in order to retrieve S3 bucket rule parameters, the 'fields' option should be set to '**'.
  • vserver object-store-server bucket lifecycle-management-rule show
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
name
string
path
True
The name of the lifecycle management rule to be applied on the bucket.
svm.uuid
string
path
True
  • Introduced in: 9.14
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
bucket_name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
name
string
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters.
non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
object_filter
object_filter
Specifies a way to filter objects within a bucket.
svm
svm
Specifies the name of the SVM where this bucket exists.
uuid
string
Specifies the unique identifier of the bucket.
      "href": "/api/resourcelink"
  "abort_incomplete_multipart_upload": {
  "bucket_name": "bucket1",
  "expiration": {
    "object_age_days": 100,
    "object_expiry_date": "2039-09-22 20:00:00 -0400"
  "name": "string",
  "non_current_version_expiration": {
  "object_filter": {
    "prefix": "/logs",
    "size_greater_than": 10240,
    "size_less_than": 10485760,
    "tags": [
      "project1=projA",
      "project2=projB"
  "svm": {
    "name": "svm1",
  "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
after_initiation_days
integer
Number of days of initiation after which uploads can be aborted.
expiration
_links
_links
expired_object_delete_marker
boolean
Cleanup object delete markers.
object_age_days
integer
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
object_expiry_date
string
Specific date from when objects can expire. This cannot be used with object_age_days.
_links
_links
new_non_current_versions
integer
Number of latest non-current versions to be retained.
non_current_days
integer
Number of days after which non-current versions can be deleted.
object_filter
_links
_links
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
