Retrieve an initiator
GET /protocols/san/initiators/{svm.uuid}/{name}
Introduced In: 9.14
Retrieves an initiator.
Related ONTAP commands
lun igroup initiator show
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM for which the initiator properties are configured. |
name |
string |
path |
True |
The name of the initiator. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
comment |
string |
A user-specified comment. |
name |
string |
protocol |
string |
The protocol of the initiator. |
svm |
The SVM for which the initiator properties are configured. |
"comment": "My initiator comment.",
"name": "iqn.2018-02.com.netapp.iscsi:name1",
"protocol": "iscsi",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
