Retrieve an initiator
GET /protocols/san/initiators/{svm.uuid}/{name}
Introduced In: 9.14
Retrieves an initiator.
Related ONTAP commands
lun igroup initiator show
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM for which the initiator properties are configured. |
name |
string |
path |
True |
The name of the initiator. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
comment |
string |
A user-specified comment. |
name |
string |
protocol |
string |
The protocol of the initiator. |
proximity |
Properties that define to what SVMs the initiator is proximal. This information is used to properly report active optimized and active non-optimized network paths via ALUA. If no configuration has been specified for the initiator, the sub-object will not be present in GET. These properties apply to all instances of the initiator in all initiator groups in the SVM and its peers. |
svm |
The SVM for which the initiator properties are configured. |
"comment": "My initiator comment.",
"name": "iqn.2018-02.com.netapp.iscsi:name1",
"protocol": "iscsi",
"proximity": {
"peer_svms": [
"href": "/api/resourcelink"
"name": "peer1",
"uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
peer_svms
A reference to an SVM peer relationship.
_links |
name |
string |
The local name of the peer SVM. This name is unique among all local and peer SVMs. |
uuid |
string |
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself. |
proximity
local_svm |
boolean |
A boolean that indicates if the initiator is proximal to the SVM for which it is configured. |
peer_svms |
array[peer_svms] |
An array of remote peer SVMs to which the initiator is proximal. |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
