REST API reference
Retrieve an initiator
GET /protocols/san/initiators/{svm.uuid}/{name}
Introduced In: 9.14
Retrieves an initiator.
  • lun igroup initiator show
svm.uuid
string
path
True
The unique identifier of the SVM for which the initiator properties are configured.
name
string
path
True
The name of the initiator.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
comment
string
A user-specified comment.
name
string
protocol
string
The protocol of the initiator.
svm
svm
The SVM for which the initiator properties are configured.
  "comment": "My initiator comment.",
  "name": "iqn.2018-02.com.netapp.iscsi:name1",
  "protocol": "iscsi",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
