Retrieve iSCSI credentials
Retrieves iSCSI credentials to access and manage iSCSI resources in ONTAP. This is useful for configuring and maintaining secure connections to your storage systems.
HTTP method and endpoint
GET /protocols/san/iscsi/credentials
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver iscsi security show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
initiator_address.masks.address |
string |
query |
False |
Filter by initiator_address.masks.address |
initiator_address.masks.family |
string |
query |
False |
Filter by initiator_address.masks.family |
initiator_address.masks.netmask |
string |
query |
False |
Filter by initiator_address.masks.netmask |
initiator_address.ranges.family |
string |
query |
False |
Filter by initiator_address.ranges.family |
initiator_address.ranges.end |
string |
query |
False |
Filter by initiator_address.ranges.end |
initiator_address.ranges.start |
string |
query |
False |
Filter by initiator_address.ranges.start |
authentication_type |
string |
query |
False |
Filter by authentication_type |
chap.outbound.user |
string |
query |
False |
Filter by chap.outbound.user
chap.inbound.user |
string |
query |
False |
Filter by chap.inbound.user
initiator |
string |
query |
False |
Filter by initiator |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[iscsi_credentials] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"authentication_type": "string",
"chap": {
"inbound": {
"user": "string"
"outbound": {
"user": "string"
"initiator": "iqn.1998-01.com.corp.iscsi:name1",
"initiator_address": {
"masks": [
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ranges": [
"end": "10.10.10.7",
"family": "string",
"start": "10.10.10.7"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
inbound
Inbound CHAP credentials.
user |
string |
The inbound CHAP user name. Optional in POST and PATCH. |
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
user |
string |
The outbound CHAP user name. Optional in POST and PATCH. To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH. |
chap
Challenge-Handshake Authentication Protocol (CHAP) credentials.
inbound |
Inbound CHAP credentials. |
outbound |
Output CHAP credentials. To clear previously set outbound CHAP credentials, set property |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip_address_range
IP address range
end |
string |
family |
string |
IPv4 or IPv6 |
start |
string |
initiator_address
Initiator address ranges.
masks |
array[ip_info] |
ranges |
array[ip_address_range] |
svm
_links |
name |
string |
uuid |
string |
iscsi_credentials
_links |
string |
The iSCSI authentication type. Required in POST; optional in PATCH. |
chap |
Challenge-Handshake Authentication Protocol (CHAP) credentials. |
initiator |
string |
The iSCSI initiator to which the credentials apply. Required in POST. |
initiator_address |
Initiator address ranges. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
