REST API reference
Retrieve iSCSI credentials
Retrieves iSCSI credentials to access and configure iSCSI storage resources securely. Use this endpoint to ensure your systems have the necessary authentication details for seamless communication with iSCSI targets.
HTTP method and endpoint
GET /protocols/san/iscsi/credentials
Introduced in
ONTAP 9.6
  • vserver iscsi security show
authentication_type
string
query
False
Filter by authentication_type
initiator
string
query
False
Filter by initiator
chap.outbound.user
string
query
False
Filter by chap.outbound.user
  • maxLength: 128
  • minLength: 1
chap.inbound.user
string
query
False
Filter by chap.inbound.user
  • maxLength: 128
  • minLength: 1
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
initiator_address.ranges.end
string
query
False
Filter by initiator_address.ranges.end
initiator_address.ranges.family
string
query
False
Filter by initiator_address.ranges.family
initiator_address.ranges.start
string
query
False
Filter by initiator_address.ranges.start
initiator_address.masks.family
string
query
False
Filter by initiator_address.masks.family
initiator_address.masks.netmask
string
query
False
Filter by initiator_address.masks.netmask
initiator_address.masks.address
string
query
False
Filter by initiator_address.masks.address
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[iscsi_credentials]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication_type": "string",
      "chap": {
        "inbound": {
          "user": "string"
        "outbound": {
          "user": "string"
      "initiator": "iqn.1998-01.com.corp.iscsi:name1",
      "initiator_address": {
        "masks": [
            "address": "10.10.10.7",
            "family": "string",
            "netmask": "24"
        "ranges": [
            "end": "10.10.10.7",
            "family": "string",
            "start": "10.10.10.7"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
inbound
Inbound CHAP credentials.
user
string
The inbound CHAP user name. Optional in POST and PATCH.
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
user
string
The outbound CHAP user name. Optional in POST and PATCH.
To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH.
chap
Challenge-Handshake Authentication Protocol (CHAP) credentials.
inbound
inbound
outbound
outbound
ip_info
IP information
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
ip_address_range
IP address range
end
string
family
string
IPv4 or IPv6
start
string
initiator_address
Initiator address ranges.
masks
array[ip_info]
ranges
array[ip_address_range]
svm
_links
_links
name
string
uuid
string
iscsi_credentials
_links
_links
authentication_type
string
The iSCSI authentication type. Required in POST; optional in PATCH.
chap
chap
initiator
string
The iSCSI initiator to which the credentials apply. Required in POST.
initiator_address
initiator_address
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
