Retrieve iSCSI credentials
Retrieves iSCSI credentials to access and manage iSCSI targets within your storage network. This helps ensure secure communication between your hosts and storage systems.
HTTP method and endpoint
GET /protocols/san/iscsi/credentials
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver iscsi security show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
chap.inbound.user |
string |
query |
False |
Filter by chap.inbound.user |
chap.outbound.user |
string |
query |
False |
Filter by chap.outbound.user |
authentication_type |
string |
query |
False |
Filter by authentication_type |
initiator |
string |
query |
False |
Filter by initiator |
initiator_address.masks.netmask |
string |
query |
False |
Filter by initiator_address.masks.netmask |
initiator_address.masks.family |
string |
query |
False |
Filter by initiator_address.masks.family |
initiator_address.masks.address |
string |
query |
False |
Filter by initiator_address.masks.address |
initiator_address.ranges.family |
string |
query |
False |
Filter by initiator_address.ranges.family |
initiator_address.ranges.end |
string |
query |
False |
Filter by initiator_address.ranges.end |
initiator_address.ranges.start |
string |
query |
False |
Filter by initiator_address.ranges.start |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[iscsi_credentials] |
"next": {
"href": "/api/resourcelink"
"records": [
"authentication_type": "string",
"chap": {
"inbound": {
"user": "string"
"outbound": {
"user": "string"
"initiator": "iqn.1998-01.com.corp.iscsi:name1",
"initiator_address": {
"masks": [
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ranges": [
"end": "10.10.10.7",
"family": "string",
"start": "10.10.10.7"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
inbound
Inbound CHAP credentials.
user |
string |
The inbound CHAP user name. Optional in POST and PATCH. |
outbound
Output CHAP credentials.
user |
string |
The outbound CHAP user name. Optional in POST and PATCH. |
chap
Challenge-Handshake Authentication Protocol (CHAP) credentials.
inbound |
Inbound CHAP credentials. |
outbound |
Output CHAP credentials. |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip_address_range
IP address range
end |
string |
family |
string |
IPv4 or IPv6 |
start |
string |
initiator_address
Initiator address ranges.
masks |
array[ip_info] |
ranges |
array[ip_address_range] |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
iscsi_credentials
_links |
string |
The iSCSI authentication type. Required in POST and optional in PATCH. |
chap |
Challenge-Handshake Authentication Protocol (CHAP) credentials. |
initiator |
string |
The iSCSI initiator to which the credentials apply. Required in POST. |
initiator_address |
Initiator address ranges. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
