REST API reference
Define a remote syslog or splunk server to receive audit information
Define a remote syslog or Splunk server to configure where audit information is sent for monitoring and analysis. Use this endpoint to set up centralized logging for audit data.
HTTP method and endpoint
GET /security/audit/destinations
Introduced in
ONTAP 9.6
Usage notes
Defines a remote syslog/splunk server for sending audit information to.
address
string
query
False
Filter by address
message_format
string
query
False
Filter by message_format
  • Introduced in: 9.13
facility
string
query
False
Filter by facility
ipspace.uuid
string
query
False
Filter by ipspace.uuid
  • Introduced in: 9.12
ipspace.name
string
query
False
Filter by ipspace.name
port
integer
query
False
Filter by port
timestamp_format_override
string
query
False
Filter by timestamp_format_override
protocol
string
query
False
Filter by protocol
verify_server
boolean
query
False
Filter by verify_server
hostname_format_override
string
query
False
Filter by hostname_format_override
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[security_audit_log_forward]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "address": "string",
      "facility": "string",
      "hostname_format_override": "string",
      "ipspace": {
        "name": "exchange",
      "message_format": "string",
      "protocol": "string",
      "timestamp_format_override": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
address
string
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname.
facility
string
This is the standard Syslog Facility value that is used when sending audit records to a remote server.
string
Syslog Hostname Format Override
ipspace
ipspace
message_format
string
Syslog message format to be used. legacy_netapp format (variation of RFC-3164) is default message format.
port
integer
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514.
protocol
string
Log forwarding protocol
string
Syslog Timestamp Format Override.
verify_server
boolean
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
