REST API reference
Define a remote syslog or splunk server to receive audit information
Defines a remote syslog or Splunk server to send audit information, helping you manage and monitor audit logs efficiently.
HTTP method and endpoint
GET /security/audit/destinations
Introduced in
ONTAP 9.6
Usage notes
Defines a remote syslog/splunk server for sending audit information to.
protocol
string
query
False
Filter by protocol
timestamp_format_override
string
query
False
Filter by timestamp_format_override
  • Introduced in: 9.13
port
integer
query
False
Filter by port
address
string
query
False
Filter by address
hostname_format_override
string
query
False
Filter by hostname_format_override
ipspace.uuid
string
query
False
Filter by ipspace.uuid
  • Introduced in: 9.12
ipspace.name
string
query
False
Filter by ipspace.name
verify_server
boolean
query
False
Filter by verify_server
facility
string
query
False
Filter by facility
message_format
string
query
False
Filter by message_format
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[security_audit_log_forward]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "address": "1.1.1.1",
      "facility": "string",
      "hostname_format_override": "string",
      "ipspace": {
        "name": "Default",
      "message_format": "string",
      "port": 514,
      "protocol": "string",
      "timestamp_format_override": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
address
string
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname.
facility
string
This is the standard Syslog Facility value that is used when sending audit records to a remote server.
string
Syslog Hostname Format Override
ipspace
ipspace
message_format
string
Syslog message format to be used. legacy_netapp format (variation of RFC-3164) is default message format.
port
integer
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514.
protocol
string
Log forwarding protocol
string
Syslog Timestamp Format Override.
verify_server
boolean
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
