Define a remote syslog or splunk server to receive audit information
Defines a remote syslog or Splunk server to receive audit information and send audit data to an external server for centralized logging and analysis.
HTTP method and endpoint
GET /security/audit/destinations
Introduced in
ONTAP 9.6
Usage notes
Defines a remote syslog/splunk server for sending audit information to.
address |
string |
query |
False |
Filter by address |
timestamp_format_override |
string |
query |
False |
Filter by timestamp_format_override
verify_server |
boolean |
query |
False |
Filter by verify_server |
hostname_format_override |
string |
query |
False |
Filter by hostname_format_override
facility |
string |
query |
False |
Filter by facility |
port |
integer |
query |
False |
Filter by port |
protocol |
string |
query |
False |
Filter by protocol |
ipspace.name |
string |
query |
False |
Filter by ipspace.name
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid
message_format |
string |
query |
False |
Filter by message_format
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[security_audit_log_forward] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"address": "string",
"facility": "string",
"hostname_format_override": "string",
"ipspace": {
"name": "exchange",
"message_format": "string",
"protocol": "string",
"timestamp_format_override": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
address |
string |
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname. |
facility |
string |
This is the standard Syslog Facility value that is used when sending audit records to a remote server. |
string |
Syslog Hostname Format Override |
ipspace |
message_format |
string |
Syslog message format to be used. legacy_netapp format (variation of RFC-3164) is default message format. |
port |
integer |
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514. |
protocol |
string |
Log forwarding protocol |
string |
Syslog Timestamp Format Override. |
verify_server |
boolean |
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
