Retrieve multi-admin-verify rules
Retrieves multi-admin-verify rules to understand the current verification settings configured in the system. This helps ensure the integrity of administrative actions by requiring multiple approvals.
HTTP method and endpoint
GET /security/multi-admin-verify/rules
Introduced in
ONTAP 9.11
query |
string |
query |
False |
Filter by query |
execution_expiry |
string |
query |
False |
Filter by execution_expiry |
required_approvers |
integer |
query |
False |
Filter by required_approvers |
system_defined |
boolean |
query |
False |
Filter by system_defined |
auto_request_create |
boolean |
query |
False |
Filter by auto_request_create |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
approval_groups.name |
string |
query |
False |
Filter by approval_groups.name |
approval_expiry |
string |
query |
False |
Filter by approval_expiry |
create_time |
string |
query |
False |
Filter by create_time |
operation |
string |
query |
False |
Filter by operation |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[multi_admin_verify_rule] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"approval_expiry": "string",
"approval_groups": [
"name": "string"
"create_time": "string",
"execution_expiry": "string",
"operation": "string",
"owner": {
"name": "svm1",
"query": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
approval_groups
name |
string |
Name of the approval group. |
_links
self |
owner
The owner of the rule. The only valid owner is currently the cluster.
_links |
name |
string |
uuid |
string |
approval_expiry |
string |
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used. |
approval_groups |
array[approval_groups] |
List of approval groups that are allowed to approve requests for rules that don't have approval groups. |
boolean |
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
create_time |
string |
execution_expiry |
string |
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used. |
operation |
string |
Command that requires one or more approvals. |
owner |
The owner of the rule. The only valid owner is currently the cluster. |
query |
string |
When specified, this property limits the entries that require approvals to those that match the specified query. |
integer |
The number of required approvers, excluding the user that made the request. |
system_defined |
boolean |
Specifies whether the rule is system-defined or user-defined. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
