REST API reference
Retrieve multi-admin-verify rules
Retrieves multi-admin-verify rules to check the current configuration and ensure that administrative actions require multiple approvals.
HTTP method and endpoint
GET /security/multi-admin-verify/rules
Introduced in
ONTAP 9.11
operation
string
query
False
Filter by operation
create_time
string
query
False
Filter by create_time
approval_groups.name
string
query
False
Filter by approval_groups.name
execution_expiry
string
query
False
Filter by execution_expiry
query
string
query
False
Filter by query
auto_request_create
boolean
query
False
Filter by auto_request_create
owner.uuid
string
query
False
Filter by owner.uuid
owner.name
string
query
False
Filter by owner.name
system_defined
boolean
query
False
Filter by system_defined
approval_expiry
string
query
False
Filter by approval_expiry
required_approvers
integer
query
False
Filter by required_approvers
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[multi_admin_verify_rule]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "approval_expiry": "string",
      "approval_groups": [
          "name": "string"
      "create_time": "string",
      "execution_expiry": "string",
      "operation": "string",
      "owner": {
        "name": "svm1",
      "query": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
approval_groups
name
string
Name of the approval group.
self
owner
The owner of the rule. The only valid owner is currently the cluster.
_links
_links
name
string
The name of the SVM. This field cannot be specified in a POST or PATCH method.
uuid
string
approval_expiry
string
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used.
approval_groups
array[approval_groups]
List of approval groups that are allowed to approve requests for rules that don't have approval groups.
auto_request_create
boolean
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
  • Default value:
  • Introduced in: 9.11
  • x-nullable: true
create_time
string
execution_expiry
string
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used.
operation
string
Command that requires one or more approvals.
owner
owner
query
string
When specified, this property limits the entries that require approvals to those that match the specified query.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
system_defined
boolean
Specifies whether the rule is system-defined or user-defined.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
