Retrieve multi-admin-verify rules
GET /security/multi-admin-verify/rules
Introduced In: 9.11
Retrieves multi-admin-verify rules.
auto_request_create  |
boolean  |
query  |
False  |
Filter by auto_request_create  |
query  |
string  |
query  |
False  |
Filter by query  |
execution_expiry  |
string  |
query  |
False  |
Filter by execution_expiry  |
create_time  |
string  |
query  |
False  |
Filter by create_time  |
approval_expiry  |
string  |
query  |
False  |
Filter by approval_expiry  |
operation  |
string  |
query  |
False  |
Filter by operation  |
required_approvers  |
integer  |
query  |
False  |
Filter by required_approvers  |
owner.name  |
string  |
query  |
False  |
Filter by owner.name  |
owner.uuid  |
string  |
query  |
False  |
Filter by owner.uuid  |
approval_groups.name  |
string  |
query  |
False  |
Filter by approval_groups.name  |
system_defined  |
boolean  |
query  |
False  |
Filter by system_defined  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[multi_admin_verify_rule]  |
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "approval_expiry": "string",
      "approval_groups": [
          "name": "string"
      "create_time": "string",
      "execution_expiry": "string",
      "operation": "string",
      "owner": {
        "name": "svm1",
      "query": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
approval_groups
name  |
string  |
Name of the approval group.  |
_links
self  |
owner
The owner of the rule. The only valid owner is currently the cluster.
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a POST or PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
approval_expiry  |
string  |
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used.  |
approval_groups  |
array[approval_groups]  |
List of approval groups that are allowed to approve requests for rules that don't have approval groups.  |
boolean  |
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
create_time  |
string  |
execution_expiry  |
string  |
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used.  |
operation  |
string  |
Command that requires one or more approvals.  |
owner  |
The owner of the rule. The only valid owner is currently the cluster.  |
query  |
string  |
When specified, this property limits the entries that require approvals to those that match the specified query.  |
integer  |
The number of required approvers, excluding the user that made the request.  |
system_defined  |
boolean  |
Specifies whether the rule is system-defined or user-defined.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
