REST API reference
Retrieve information about security configured on the cluster
Retrieves information about the security setup on the cluster to understand its current security configuration.
HTTP method and endpoint
GET /security
Introduced in
ONTAP 9.7
Usage notes
Retrieves information about the security configured on the cluster.
  • security config show
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
fips
fips
Cluster-wide Federal Information Processing Standards (FIPS) mode information.
management_protocols
Cluster-wide security protocols related information.
onboard_key_manager_configurable_status
Indicates whether the Onboard Key Manager can be configured in the cluster.
software_data_encryption
Cluster-wide software data encryption related information.
tls
tls
Cluster-wide Transport Layer Security (TLS) configuration information
      "href": "/api/resourcelink"
  "onboard_key_manager_configurable_status": {
    "code": 65537300,
    "message": "No platform support for volume encryption in following nodes - node1, node2."
  "tls": {
    "cipher_suites": [
      "TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384"
    "protocol_versions": [
      "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
fips
enabled
boolean
Indicates whether or not the software FIPS mode is enabled on the cluster. Our FIPS compliance involves configuring the use of only approved algorithms in applicable contexts (for example TLS), as well as the use of formally validated cryptographic module software implementations, where applicable. The US government documents concerning FIPS 140-2 outline the relevant security policies in detail.
rsh_enabled
boolean
Indicates whether or not security protocol rsh is enabled on the cluster.
telnet_enabled
boolean
Indicates whether or not security protocol telnet is enabled on the cluster.
code
integer
Code corresponding to the status message. Returns a 0 if the Onboard Key Manager can be configured in the cluster.
message
string
Reason that Onboard Key Manager cannot be configured in the cluster.
supported
boolean
Set to true if the Onboard Key Manager can be configured in the cluster.
conversion_enabled
boolean
Indicates whether or not software encryption conversion is enabled on the cluster. A PATCH request initiates the conversion of all non-encrypted metadata volumes in the cluster to encrypted metadata volumes and all non-NAE aggregates to NAE aggregates. For the PATCH request to start, the cluster must have either an Onboard or an external key manager set up and the aggregates should either be empty or have only metadata volumes. No data volumes should be present in any of the aggregates in the cluster. For MetroCluster configurations, a PATCH request enables conversion on all the aggregates and metadata volumes of both local and remote clusters and is not allowed when the MetroCluster is in switchover state.
disabled_by_default
boolean
Indicates whether or not default software data at rest encryption is disabled on the cluster.
tls
cipher_suites
array[string]
Names a cipher suite that the system can select during TLS handshakes. A list of available options can be found on the Internet Assigned Number Authority (IANA) website.
protocol_versions
array[string]
Names a TLS protocol version that the system can select during TLS handshakes. The use of SSLv3 or TLSv1 is discouraged.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
