Retrieve information about security configured on the cluster
GET /security
Retrieves information about the security configured on the cluster.
Learn more
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
desc] direction. Default direction is 'asc' for ascending.  |
fields  |
array[string]  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
_links  |
onboard_key_manager_configurable_status  |
Indicates whether the Onboard Key Manager can be configured in the cluster.  |
      "href": "/api/resourcelink"
  "onboard_key_manager_configurable_status": {
    "code": 65537300,
    "message": "No platform support for volume encryption in following nodes - node1, node2."
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
code  |
integer  |
Code corresponding to the status message. Returns a 0 if the Onboard Key Manager can be configured in the cluster.  |
message  |
string  |
Reason that Onboard Key Manager cannot be configured in the cluster.  |
supported  |
boolean  |
Set to true if the Onboard Key Manager can be configured in the cluster.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
