Retrieve information about security configured on the cluster
GET /security
Introduced In: 9.7
Retrieves information about the security configured on the cluster.
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
fips |
Cluster-wide Federal Information Processing Standards (FIPS) mode information. |
onboard_key_manager_configurable_status |
Indicates whether the Onboard Key Manager can be configured in the cluster. |
software_data_encryption |
Cluster-wide software data encryption related information. |
"href": "/api/resourcelink"
"onboard_key_manager_configurable_status": {
"code": "65537300",
"message": "No platform support for volume encryption in following nodes - node1, node2."
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
fips
enabled |
boolean |
Indicates whether or not the software FIPS mode is enabled on the cluster. Our FIPS compliance involves configuring the use of only approved algorithms in applicable contexts (for example TLS), as well as the use of formally validated cryptographic module software implementations, where applicable. The US government documents concerning FIPS 140-2 outline the relevant security policies in detail. |
code |
integer |
Code corresponding to the status message. Returns a 0 if the Onboard Key Manager can be configured in the cluster. |
message |
string |
Reason that Onboard Key Manager cannot be configured in the cluster. |
supported |
boolean |
Set to true if the Onboard Key Manager can be configured in the cluster. |
conversion_enabled |
boolean |
Indicates whether or not software encryption conversion is enabled on the cluster. A PATCH request initiates the conversion of all non-encrypted metadata volumes in the cluster to encrypted metadata volumes and all non-NAE aggregates to NAE aggregates. For the PATCH request to start, the cluster must have either an Onboard or an external key manager set up and the aggregates should either be empty or have only metadata volumes. No data volumes should be present in any of the aggregates in the cluster. For MetroCluster configurations, a PATCH request enables conversion on all the aggregates and metadata volumes of both local and remote clusters and is not allowed when the MetroCluster is in switchover state. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
