Retrieve information about an AutoSupport message
GET /support/autosupport/messages/{node.uuid}/{index}/{destination}
Introduced In: 9.14
Retrieves information about a single Autosupport message.
node.uuid  |
string  |
path  |
True  |
Node UUID  |
index  |
string  |
path  |
True  |
AutoSupport message sequence number  |
destination  |
string  |
path  |
True  |
The destination for this AutoSupport message.
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
destination  |
string  |
Destination for the AutoSupport  |
error  |
Last error during delivery attempt. Empty if "status=sent-successful".  |
generated_on  |
string  |
Date and Time of AutoSupport generation in ISO-8601 format  |
index  |
integer  |
Sequence number of the AutoSupport  |
node  |
state  |
string  |
State of AutoSupport delivery  |
subject  |
string  |
Subject line for the AutoSupport  |
  "destination": "http",
  "error": {
    "code": "53149746",
    "message": "Could not resolve host: test.com"
  "generated_on": "2019-03-25 17:30:04 -0400",
  "index": 9,
  "node": {
        "href": "/api/resourcelink"
    "name": "node1",
  "state": "sent_successful",
  "subject": "WEEKLY_LOG"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
error
code  |
integer  |
Error code  |
message  |
string  |
Error message  |
href  |
string  |
_links
self  |
node
_links  |
name  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
