REST API reference
Retrieve information about an AutoSupport message
Accesses detailed information about a specific AutoSupport message. This helps you monitor and troubleshoot system events effectively.
HTTP method and endpoint
GET /support/autosupport/messages/{node.uuid}/{index}/{destination}
Introduced in
ONTAP 9.14
Usage notes
Retrieves information about a single Autosupport message.
node.uuid
string
path
True
Node UUID
index
string
path
True
AutoSupport message sequence number
destination
string
path
True
The destination for this AutoSupport message.
  • enum: ["smtp", "http", "noteto", "retransmit"]
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
destination
string
Destination for the AutoSupport
error
error
Last error during delivery attempt. Empty if "status=sent-successful".
generated_on
string
Date and Time of AutoSupport generation in ISO-8601 format
index
integer
Sequence number of the AutoSupport
node
node
state
string
State of AutoSupport delivery
subject
string
Subject line for the AutoSupport
  "destination": "http",
  "error": {
    "code": "53149746",
    "message": "Could not resolve host: test.com"
  "generated_on": "2019-03-25 17:30:04 -0400",
  "index": 9,
  "node": {
        "href": "/api/resourcelink"
    "name": "node1",
  "state": "sent_successful",
  "subject": "WEEKLY_LOG"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
error
code
integer
Error code
message
string
Error message
string
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
