Retrieve information about an AutoSupport message
GET /support/autosupport/messages/{node.uuid}/{index}/{destination}
Introduced In: 9.14
Retrieves information about a single Autosupport message.
node.uuid |
string |
path |
True |
Node UUID |
index |
string |
path |
True |
AutoSupport message sequence number |
destination |
string |
path |
True |
The destination for this AutoSupport message.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
destination |
string |
Destination for the AutoSupport |
error |
Last error during delivery attempt. Empty if "status=sent-successful". |
generated_on |
string |
Date and Time of AutoSupport generation in ISO-8601 format |
index |
integer |
Sequence number of the AutoSupport |
node |
state |
string |
State of AutoSupport delivery |
subject |
string |
Subject line for the AutoSupport |
"href": "/api/resourcelink"
"destination": "http",
"error": {
"code": "53149746",
"message": "Could not resolve host: test.com"
"generated_on": "2019-03-25 17:30:04 -0400",
"index": 9,
"node": {
"name": "node1",
"state": "sent_successful",
"subject": "WEEKLY_LOG"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
error
code |
integer |
Error code |
message |
string |
Error message |
_links
self |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
