Retrieve SNMP traphost details
Retrieves the details of an SNMP traphost, including the SNMP user configured for that traphost, to manage and monitor SNMP notifications effectively.
HTTP method and endpoint
GET /support/snmp/traphosts/{host}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the details of an SNMP traphost along with the SNMP user configured for that traphost.
Learn more
host |
string |
path |
True |
Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost. |
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
host |
string |
Fully qualified domain name (FQDN), IPv4 address or IPv6 address of SNMP traphost. |
ip_address |
string |
IPv4 or IPv6 address |
user |
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community. |
"href": "/api/resourcelink"
"host": "traphost.example.com",
"ip_address": "10.10.10.7",
"user": {
"name": "snmpv3user3"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
user
_links |
name |
string |
Optional SNMPv1/SNMPv2c or SNMPv3 user name. For an SNMPv3 traphost, this object refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this object refers to an SNMP community. For an SNMPv3 traphost, this object is mandatory and refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, ONTAP automatically uses "public", if the same is configured, or any other configured community as user. So, for an SNMPv1 or SNMPv2c traphost, this property should not be provided in the "POST" method. However, the configured community for the SNMPv1/SNMPv2c traphost is returned by the "GET" method.
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
