REST API reference
Retrieve SNMP traphost details
Retrieves SNMP traphost details to access the configurations and associated SNMP user information for monitoring and management purposes.
HTTP method and endpoint
GET /support/snmp/traphosts/{host}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the details of an SNMP traphost along with the SNMP user configured for that traphost.
host
string
path
True
Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost.
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
_links
_links
host
string
Fully qualified domain name (FQDN), IPv4 address or IPv6 address of SNMP traphost.
ip_address
string
IPv4 or IPv6 address
user
user
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community.
      "href": "/api/resourcelink"
  "host": "traphost.example.com",
  "ip_address": "10.10.10.7",
  "user": {
    "name": "snmpv3user3"
Status: Default
ONTAP Error Response Codes
Error Code Description
8847365
Unknown host.
9043970
Traphost entry does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
user
_links
_links
name
string
Optional SNMPv1/SNMPv2c or SNMPv3 user name. For an SNMPv3 traphost, this object refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this object refers to an SNMP community. For an SNMPv3 traphost, this object is mandatory and refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, ONTAP automatically uses "public", if the same is configured, or any other configured community as user. So, for an SNMPv1 or SNMPv2c traphost, this property should not be provided in the "POST" method. However, the configured community for the SNMPv1/SNMPv2c traphost is returned by the "GET" method.
  • example: snmpv3user3
  • Introduced in: 9.7
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
