Retrieve SNMP traphost details
GET /support/snmp/traphosts/{host}
Introduced In: 9.7
Retrieves the details of an SNMP traphost along with the SNMP user configured for that traphost.
Learn more
host  |
string  |
path  |
True  |
Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
return_timeout  |
integer  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
_links  |
host  |
string  |
Fully qualified domain name (FQDN), IPv4 address or IPv6 address of SNMP traphost.  |
ip_address  |
string  |
IPv4 or IPv6 address  |
user  |
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community.  |
      "href": "/api/resourcelink"
  "host": "traphost.example.com",
  "ip_address": "10.10.10.7",
  "user": {
    "name": "snmpv3user3"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8847365  |
Unknown host.  |
9043970  |
Traphost entry does not exist.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
user
_links  |
name  |
string  |
Optional SNMPv1/SNMPv2c or SNMPv3 user name. For an SNMPv3 traphost, this object refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this object refers to an SNMP community. For an SNMPv3 traphost, this object is mandatory and refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, ONTAP automatically uses "public", if the same is configured, or any other configured community as user. So, for an SNMPv1 or SNMPv2c traphost, this property should not be provided in the "POST" method. However, the configured community for the SNMPv1/SNMPv2c traphost is returned by the "GET" method.
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
