Manage cluster-wide storage
Access cluster-wide storage details through these endpoints to gain insight into storage efficiency, block storage, and cloud storage across different tiers. Use this information to optimize storage utilization and performance within your ONTAP environment.
Retrieves cluster-wide storage details across the different tiers. Storage details include storage efficiency, block storage and cloud storage information.
Example
Retrieving cluster-wide storage details
The following example shows the details returned for a GET request on cluster-wide storage:
# The API:
/api/storage/cluster
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/cluster" -H "accept: application/hal+json"
# The response:
"efficiency": {
"savings": 143360,
"ratio": 1.134099616858238,
"logical_used": 1212416
"efficiency_without_snapshots": {
"savings": 0,
"ratio": 1,
"logical_used": 167936
"efficiency_without_snapshots_flexclones": {
"savings": 0,
"ratio": 1,
"block_storage": {
"used": 6269812736,
"size": 56125612032,
"available": 49855799296,
"physical_used": 1838284800,
"inactive_data": 0,
"medias": [
"type": "ssd",
"size": 9891430400,
"available": 3728039936,
"used": 6163390464,
"physical_used": 1832886272,
"efficiency": {
"savings": 0,
"ratio": 1,
"logical_used": 0
"savings": 0,
"ratio": 1,
"logical_used": 0
"savings": 0,
"ratio": 1,
"logical_used": 0
"type": "vmdisk",
"size": 46234181632,
"available": 46127759360,
"used": 106422272,
"physical_used": 5398528,
"efficiency": {
"savings": 282624,
"ratio": 1.303964757709251,
"savings": 0,
"ratio": 1,
"savings": 0,
"ratio": 1,
