REST API reference
Manage cluster-wide storage
Retrieve and assess cluster-wide storage details to understand the efficiency, block storage, and cloud storage across different tiers. Use these endpoints to gain insights into storage usage and optimize resource allocation within your ONTAP environment.
Retrieves cluster-wide storage details across the different tiers. Storage details include storage efficiency, block storage and cloud storage information.
Example
Retrieving cluster-wide storage details
The following example shows the details returned for a GET request on cluster-wide storage:
# The API:
/api/storage/cluster
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/cluster" -H "accept: application/hal+json"
# The response:
"efficiency": {
  "savings": 143360,
  "ratio": 1.134099616858238,
  "logical_used": 1212416
"efficiency_without_snapshots": {
  "savings": 0,
  "ratio": 1,
  "logical_used": 167936
"efficiency_without_snapshots_flexclones": {
  "savings": 0,
  "ratio": 1,
"block_storage": {
  "used": 6269812736,
  "size": 56125612032,
  "available": 49855799296,
  "physical_used": 1838284800,
  "inactive_data": 0,
  "medias": [
      "type": "ssd",
      "size": 9891430400,
      "available": 3728039936,
      "used": 6163390464,
      "physical_used": 1832886272,
      "efficiency": {
        "savings": 0,
        "ratio": 1,
        "logical_used": 0
        "savings": 0,
        "ratio": 1,
        "logical_used": 0
        "savings": 0,
        "ratio": 1,
        "logical_used": 0
      "type": "vmdisk",
      "size": 46234181632,
      "available": 46127759360,
      "used": 106422272,
      "physical_used": 5398528,
      "efficiency": {
        "savings": 282624,
        "ratio": 1.303964757709251,
        "savings": 0,
        "ratio": 1,
        "savings": 0,
        "ratio": 1,
