Manage cluster-wide storage
Retrieve detailed information about cluster-wide storage, including storage efficiency and data from block and cloud storage tiers. Use these endpoints to gain insights into your storage environment's capacity and performance across different tiers.
Retrieves cluster-wide storage details across the different tiers. Storage details include storage efficiency, block storage and cloud storage information.
Example
Retrieving cluster-wide storage details
The following example shows the details returned for a GET request on cluster-wide storage:
# The API:
/api/storage/cluster
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/cluster" -H "accept: application/hal+json"
# The response:
"efficiency": {
"savings": 143360,
"ratio": 1.134099616858238,
"logical_used": 1212416
"efficiency_without_snapshots": {
"savings": 0,
"ratio": 1,
"logical_used": 167936
"efficiency_without_snapshots_flexclones": {
"savings": 0,
"ratio": 1,
"block_storage": {
"used": 6269812736,
"size": 56125612032,
"available": 49855799296,
"physical_used": 1838284800,
"inactive_data": 0,
"medias": [
"type": "ssd",
"size": 9891430400,
"available": 3728039936,
"used": 6163390464,
"physical_used": 1832886272,
"efficiency": {
"savings": 0,
"ratio": 1,
"logical_used": 0
"savings": 0,
"ratio": 1,
"logical_used": 0
"savings": 0,
"ratio": 1,
"logical_used": 0
"type": "vmdisk",
"size": 46234181632,
"available": 46127759360,
"used": 106422272,
"physical_used": 5398528,
"efficiency": {
"savings": 282624,
"ratio": 1.303964757709251,
"savings": 0,
"ratio": 1,
"savings": 0,
"ratio": 1,
