Manage the multi-admin-verify global setting
Access and modify the multi-admin verification global setting to enhance security within your ONTAP environment. Retrieve current values or update the configuration as needed using these endpoints.
Overview
These APIs provide information on the multi-admin verification global setting.
The GET API retrieves the object store that contains the global setting values of the multi-admin-verify feature.
The PATCH request is used to modify the multi-admin-verify global setting. All fields are optional for the PATCH request.
Retrieving the multi-admin-verify global setting
Retrieves the current multi-admin-verify global setting. If the global setting is not set, default values are returned.
# The API:
/api/security/multi-admin-verify
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify"
# The response:
"approval_groups": [
"required_approvers": 1,
"enabled": false,
"execution_expiry": "PT1H",
"approval_expiry": "PT1H",
"href": "/api/security/multi-admin-verify"
Updating the multi-admin-verify global setting
The following example updates the multi-admin-verify global settings.
Note that the approval_groups needs to be available in /security/multi-admin-verify/approval-groups before it is set in the global setting.
# The API:
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/multi-admin-verify" -d '{"required_approvers": "1", "enabled": "true", "execution_expiry": "2h", "approval_expiry": "3h"}'
