REST API reference
Manage the multi-admin-verify global setting
Access and modify the multi-admin verification global setting to manage security features in your ONTAP environment. Retrieve current settings or update them to ensure consistent configuration across peered clusters.
Overview
These APIs provide information on the multi-admin verification global setting. The GET API retrieves the object store that contains the global setting values of the multi-admin-verify feature. The PATCH request is used to modify the multi-admin-verify global setting. All fields are optional for the PATCH request. Note it is recommended that multi-admin-verify is enabled equally on peered ONTAP clusters.
Retrieving the multi-admin-verify global setting
Retrieves the current multi-admin-verify global setting. If the global setting is not set, default values are returned.
# The API:
/api/security/multi-admin-verify
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify"
# The response:
"approval_groups": [
"required_approvers": 1,
"enabled": false,
"execution_expiry": "PT1H",
"approval_expiry": "PT1H",
    "href": "/api/security/multi-admin-verify"
Updating the multi-admin-verify global setting
The following example updates the multi-admin-verify global settings. Note that the approval_groups needs to be available in /security/multi-admin-verify/approval-groups before it is set in the global setting. Note that the total number of approvers in an approval group must be a positive integer more than the number of required approvers. For example, if there are a total of 10 approvers in a group, the required approvers can be set between 1 and 9.
# The API:
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/multi-admin-verify" -d '{"required_approvers": "1", "enabled": "true", "execution_expiry": "2h", "approval_expiry": "3h"}'
