REST API reference
Manage the multi-admin-verify global setting
Use these APIs to retrieve or modify the multi-admin verification global setting within your ONTAP environment. You might adjust these settings to ensure consistent security measures across peered clusters.
Overview
These APIs provide information on the multi-admin verification global setting. The GET API retrieves the object store that contains the global setting values of the multi-admin-verify feature. The PATCH request is used to modify the multi-admin-verify global setting. All fields are optional for the PATCH request. Note it is recommended that multi-admin-verify is enabled equally on peered ONTAP clusters.
Retrieving the multi-admin-verify global setting
Retrieves the current multi-admin-verify global setting. If the global setting is not set, default values are returned.
# The API:
/api/security/multi-admin-verify
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify"
# The response:
"approval_groups": [
"required_approvers": 1,
"enabled": false,
"execution_expiry": "PT1H",
"approval_expiry": "PT1H",
    "href": "/api/security/multi-admin-verify"
Updating the multi-admin-verify global setting
The following example updates the multi-admin-verify global settings. Note that the approval_groups needs to be available in /security/multi-admin-verify/approval-groups before it is set in the global setting. Note that the total number of approvers in an approval group must be a positive integer more than the number of required approvers. For example, if there are a total of 10 approvers in a group, the required approvers can be set between 1 and 9.
# The API:
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/multi-admin-verify" -d '{"required_approvers": "1", "enabled": "true", "execution_expiry": "2h", "approval_expiry": "3h"}'
