Enable a keystore configuration
PATCH /security/key-stores/{uuid}
Introduced In: 9.14
Enables a keystore configuration
Related ONTAP commands
security key-manager keystore enable
Name | Type | In | Required | Description |
uuid |
string |
path |
True |
Keystore configuration UUID |
return_timeout |
integer |
query |
False |
Request Body
Name | Type | Description |
configuration |
Security keystore object reference. |
enabled |
boolean |
Indicates whether the configuration is enabled. |
location |
string |
Indicates whether the keystore is onboard or external. * 'onboard' - Onboard Key Database * 'external' - External Key Database, including KMIP and Cloud Key Management Systems |
svm |
type |
string |
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service * 'ikp' - IBM Key Protect Key Management Service |
uuid |
string |
Example request
"configuration": {
"name": "default",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"location": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code | Description |
262155 |
This operation requires an effective cluster version of 9.14.0 or later. |
65537605 |
Failed to establish connectivity with the cloud key management service. |
65538908 |
The specified keystore configuration UUID either does not exist or corresponds to a keystore configuration that is not supported by this operation. |
65538909 |
A value for enabled is required. |
65538910 |
Disabling an enabled configuration through this method is currently not supported. |
65539206 |
The SVM associated with the supplied keystore UUID already has a keystore configuration enabled. This command does not support migrating from configurations of that keystore type". |
65539212 |
Cannot switch the enabled keystore configuration when it is not in the 'active' or 'switching' state. |
href |
string |
_links
configuration
name |
string |
Name of the configuration. |
uuid |
string |
Keystore UUID. |
svm
name |
string |
uuid |
string |
security_keystore
configuration |
enabled |
boolean |
location |
string |
svm |
type |
string |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
