REST API reference
Enable a keystore configuration
PATCH /security/key-stores/{uuid}
Introduced In: 9.14
Enables a keystore configuration
  • security key-manager keystore enable
uuid
string
path
True
Keystore configuration UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
configuration
configuration
Security keystore object reference.
enabled
boolean
Indicates whether the configuration is enabled.
location
string
Indicates whether the keystore is onboard or external. * 'onboard' - Onboard Key Database * 'external' - External Key Database, including KMIP and Cloud Key Management Systems
svm
svm
type
string
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service * 'ikp' - IBM Key Protect Key Management Service
uuid
string
Example request
  "configuration": {
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "location": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
  "uuid": "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
262155
This operation requires an effective cluster version of 9.14.0 or later.
65537605
Failed to establish connectivity with the cloud key management service.
65538908
The specified keystore configuration UUID either does not exist or corresponds to a keystore configuration that is not supported by this operation.
65538909
A value for enabled is required.
65538910
Disabling an enabled configuration through this method is currently not supported.
65539206
The SVM associated with the supplied keystore UUID already has a keystore configuration enabled. This command does not support migrating from configurations of that keystore type".
65539212
Cannot switch the enabled keystore configuration when it is not in the 'active' or 'switching' state.
65539703
The key manager cannot be configured because the SVM has NAE volumes.
string
configuration
name
string
Name of the configuration.
uuid
string
Keystore UUID.
svm
name
string
uuid
string
security_keystore
configuration
configuration
enabled
boolean
location
string
svm
svm
type
string
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
