REST API reference
Enable a keystore configuration
PATCH /security/key-stores/{uuid}
Introduced In: 9.14
Enables a keystore configuration
  • security key-manager keystore enable
  • security key-manager keystore disable
uuid
string
path
True
Keystore configuration UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
configuration
configuration
Security keystore object reference.
enabled
boolean
Indicates whether the configuration is enabled.
is_svm_kek
boolean
Indicates whether the keystore is SVM-KEK based.
location
string
Indicates whether the keystore is onboard or external. * 'onboard' - Onboard Key Database * 'external' - External Key Database, including KMIP and Cloud Key Management Systems
state
string
State of the keystore: * 'active' - The key manager is active and serving new and existing keys. * 'mixed' - The key manager has a mixed configuration. New keys can't be created. * 'svm_kek_rekey' - An SVM key encryption key (KEK) rekey is in progress. New keys can't be created. * 'blocked' - The key manager is blocked and cannot serve new and existing keys. * 'switching' - Switching the enabled key manager keystore configuration. Some operations are blocked. * 'initializing' - The key manager is being initialized. All operations are blocked. * 'disabling' - The key manager is being disabled. All operations are blocked.
svm
svm
type
string
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service * 'ikp' - IBM Key Protect Key Management Service * 'barbican' - Barbican Key Management Service
uuid
string
Example request
  "configuration": {
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "location": "string",
  "state": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
  "uuid": "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
262155
This operation requires an effective cluster version of 9.14.0 or later.
65536203
Internal error. Failed to generate SVM key. Cluster key database is not initialized.
65536204
Internal error. Failed to generate SVM key. Cluster key encryption key is not found.
65536207
Internal error. Failed to store SVM key.
65536212
Internal error. Failed to delete SVM volume key.
65536217
Internal error. Failed to delete key from cryptomod.
65536602
Cannot perform enable/switch while nodes are out of quorum.
65536856
No external key management server configured for SVM.
65536882
Internal error. UUID is missing for the volume.
65536883
Internal error. Volume encryption key is missing.
65536884
Internal error. Volume encryption key is invalid for the volume.
65536889
Internal error. The volume has an invalid encryption blob.
65536890
Internal error. Failed to generate VDEK blob.
65536973
Internal error. Volume DSID is missing for the volume.
65536987
One or more key servers are unavailable.
65537527
Internal error. Failed to rewrap SVM key encryption key.
65537533
Internal error. Failed to unwrap SVM key encryption key.
65537605
Failed to establish connectivity with the cloud key management service.
65538908
The specified keystore configuration UUID either does not exist or corresponds to a keystore configuration that is not supported by this operation.
65538909
A value for enabled is required.
65538910
Disabling an enabled configuration through this method is currently not supported.
65539200
The key custodian was not provided with an external key value store.
65539201
Failed to encrypt.
65539205
This command does not support enabling key manager configurations with the specified keystore type.
65539206
The SVM associated with the supplied keystore UUID already has a keystore configuration enabled. This command does not support migrating from configurations of that keystore type".
65539207
The specified keystore configuration does not exist.
65539212
Cannot switch the enabled keystore configuration when it is not in the 'active' or 'switching' state.
65539218
The specified keystore configuration is already enabled.
65539222
Switching between configurations of different keystore types is not supported for data SVMs.
65539416
Internal error. Failed to parse key value store response.
65539442
Internal error. Failed to generate AES blob.
65539444
Internal error. Failed to update the VDEK blob.
65539513
An effective cluster version of ONTAP 9.16.1 or later is required to enable an inactive key manager on the admin SVM.
65539514
This command does not support enabling key manager configurations with the specified keystore type on the admin SVM.
65539515
Cannot switch keystore types on the admin SVM. The keystore type for the invalid configuration must be OKM and the enabled configuration must be KMIP, or vice versa.
65539518
Internal error. Cannot find the enabled configuration.
65539520
Cannot enable the Onboard Key Manager on the admin SVM because an inactive Onboard Key Manager already exists on the admin SVM.
65539534
Cannot switch admin SVM Key Manager when system root volumes are present.
65539535
Failed to find unwrapped key on any nodes.
65539536
Internal error. Failed to find the existing wrapped key blob for the volume.
65539538
SVM-KEK not created for the SVM.
65539539
SVM-KEK not restored for SVM.
65539583
Cannot switch to the Onboard Key Manager when the external key manager has a policy associated with it
65539585
Cannot enable an external key manager on the admin SVM because an inactive external key manager already exists on the admin SVM.
65539590
Cannot switch to the Onboard Key Manager if there are more than two NSE-AKs in the cluster.
65539591
Cannot switch to the Onboard Key Manager if there are fewer than two NSE-AKs in the cluster.
65539622
CKEK not restored for SVM.
65539704
The key manager cannot be configured because the SVM has NAE volumes.
65539837
The key manager configured does not have any volumes to migrate.
65539838
Cannot migrate to a cloud key manager when the external key manager has a policy associated with it.
65539839
Cannot migrate to a cloud key manager when the key manager is not in a mixed state.
65539840
Failed to clean up the keys stored on the external key servers.
65539842
Failed to restore the SVM-KEK.
65539845
Cannot migrate SVM volumes to the Onboard Key Manager when the key manager is not in the mixed or active state.
65539857
During the keystore switch operation, a restore operation failed.
65539858
During the key migration operation, a restore operation failed.
65539859
string
configuration
name
string
Name of the configuration.
uuid
string
Keystore UUID.
svm
name
string
uuid
string
security_keystore
configuration
configuration
enabled
boolean
is_svm_kek
boolean
location
string
state
string
svm
svm
type
string
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
