REST API reference
Update the SSH server configuration for an SVM
Updates the SSH server configuration for a specific SVM, ensuring the settings meet your security requirements. Adjustments can include encryption algorithms, key exchange algorithms, and authentication retry limits.
HTTP method and endpoint
PATCH /security/ssh/svms/{svm.uuid}
Introduced in
ONTAP 9.10
Usage notes
Updates the SSH server configuration for the specified SVM.
Optional parameters
  • ciphers - Encryption algorithms for the payload
  • key_exchange_algorithms - SSH key exchange algorithms
  • mac_algorithms - MAC algorithms
  • max_authentication_retry_count - Maximum authentication retries allowed before closing the connection
  • security ssh
svm.uuid
string
path
True
SVM UUID
Request Body
Name Type Description
ciphers
array[string]
Ciphers for encrypting the data.
array[string]
Key exchange algorithms.
mac_algorithms
array[string]
MAC algorithms.
integer
Maximum authentication retries allowed before closing the connection.
svm
svm
SVM name and UUID for which the SSH server is configured.
Example request
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "ecdh_sha2_nistp256"
  "mac_algorithms": [
    "hmac_sha2_512",
    "hmac_sha2_512_etm"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10682372
There must be at least one key exchange algorithm associated with the SSH configuration.
10682373
There must be at least one cipher associated with the SSH configuration.
10682375
Failed to modify SSH key exchange algorithms.
10682378
Failed to modify SSH ciphers.
10682399
Key exchange algorithm not supported in FIPS-enabled mode.
10682400
Failed to modify SSH MAC algorithms.
10682401
MAC algorithm not supported in FIPS-enabled mode.
10682403
There must be at least one MAC algorithm with the SSH configuration.
10682413
Failed to modify maximum authentication retry attempts.
10682418
Cipher not supported in FIPS-enabled mode.
string
svm
name
string
uuid
string
svm_ssh_server
ciphers
array[string]
array[string]
mac_algorithms
array[string]
MAC algorithms.
integer
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
