Update the SSH server configuration for an SVM
Updates the SSH server configuration for a specific data SVM, adjusting settings such as encryption and authentication algorithms to meet your security requirements.
HTTP method and endpoint
PATCH /security/ssh/svms/{svm.uuid}
Introduced in
ONTAP 9.10
Usage notes
Updates the SSH server configuration for the specified data SVM.
Optional parameters
ciphers- Encryption algorithms for the payload -
key_exchange_algorithms- SSH key exchange algorithms -
host_key_algorithms- Host key algorithms -
mac_algorithms- MAC algorithms -
max_authentication_retry_count- Maximum authentication retries allowed before closing the connection -
is_rsa_in_publickey_algorithms_enabled- ssh-rsa enabled status for public key algorithms -
login_grace_time- Login grace time allowed for SSH connection
Related ONTAP commands
security ssh
svm.uuid |
string |
path |
True |
SVM UUID |
Request Body
| Name | Type | Description |
ciphers |
array[string] |
Ciphers for encrypting the data. |
host_key_algorithms |
array[string] |
Host key algorithms. The host key algorithms 'ssh_ed25519' and 'ssh_rsa' can be configured only in non-FIPS mode. |
is_rsa_in_publickey_algorithms_enabled |
boolean |
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA. |
key_exchange_algorithms |
array[string] |
Key exchange algorithms. |
login_grace_time |
integer |
The login grace time allowed for SSH connection request timeout. |
mac_algorithms |
array[string] |
MAC algorithms. |
max_authentication_retry_count |
integer |
Maximum authentication retries allowed before closing the connection. |
svm |
SVM name and UUID for which the SSH server is configured. |
Example request
"ciphers": [
"aes256_ctr",
"aes192_ctr",
"aes128_ctr"
"host_key_algorithms": [
"ecdsa_sha2_nistp256",
"ssh_ed25519",
"ssh_rsa",
"rsa_sha2_256",
"rsa_sha2_512"
"key_exchange_algorithms": [
"diffie_hellman_group_exchange_sha256",
"ecdh_sha2_nistp256"
"mac_algorithms": [
"hmac_sha2_512",
"hmac_sha2_512_etm"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10682372 |
There must be at least one key exchange algorithm associated with the SSH configuration. |
10682373 |
There must be at least one cipher associated with the SSH configuration. |
10682375 |
Failed to modify SSH key exchange algorithms. |
10682378 |
Failed to modify SSH ciphers. |
10682399 |
Key exchange algorithm not supported in FIPS-enabled mode. |
10682400 |
Failed to modify SSH MAC algorithms. |
10682401 |
MAC algorithm not supported in FIPS-enabled mode. |
10682403 |
There must be at least one MAC algorithm with the SSH configuration. |
10682413 |
Failed to modify maximum authentication retry attempts. |
10682418 |
Cipher not supported in FIPS-enabled mode. |
10682420 |
To modify the SSH configuration of the admin SVM, use the /api/security/ssh REST API. |
10682423 |
There must be at least one host key algorithm associated with the SSH configuration. |
10682424 |
Host key algorithm not supported in FIPS enabled mode. |
10682425 |
Failed to modify Host key algorithms. |
10682426 |
Failed to modify ssh-rsa enabled status for publickey algorithms configuration. |
10682428 |
Cipher not supported in FIPS enabled mode. |
10682429 |
Adding 'diffie_hellman_group16_sha512' or 'diffie_hellman_group18_sha512' to the SSH key exchange algorithms list requires an effective cluster version of ONTAP 9.16.1 or later. |
10682430 |
Failed to modify the login grace time. |
href |
string |
_links
svm
name |
string |
uuid |
string |
svm_ssh_server
ciphers |
array[string] |
array[string] |
boolean |
array[string] |
login_grace_time |
integer |
mac_algorithms |
array[string] |
MAC algorithms. |
integer |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
