REST API reference
Update the SSH server configuration for an SVM
PATCH /security/ssh/svms/{svm.uuid}
Introduced In: 9.10
Updates the SSH server configuration for the specified data SVM.
Optional parameters
  • ciphers - Encryption algorithms for the payload
  • key_exchange_algorithms - SSH key exchange algorithms
  • host_key_algorithms - Host key algorithms
  • mac_algorithms - MAC algorithms
  • max_authentication_retry_count - Maximum authentication retries allowed before closing the connection
  • is_rsa_in_publickey_algorithms_enabled - ssh-rsa enabled status for public key algorithms
  • login_grace_time - Login grace time allowed for SSH connection
  • security ssh
svm.uuid
string
path
True
SVM UUID
Request Body
Name Type Description
ciphers
array[string]
Ciphers for encrypting the data.
host_key_algorithms
array[string]
Host key algorithms. The host key algorithms 'ssh_ed25519' and 'ssh_rsa' can be configured only in non-FIPS mode.
boolean
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA.
array[string]
Key exchange algorithms.
login_grace_time
integer
The login grace time allowed for SSH connection request timeout.
mac_algorithms
array[string]
MAC algorithms.
integer
Maximum authentication retries allowed before closing the connection.
svm
svm
SVM name and UUID for which the SSH server is configured.
Example request
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "host_key_algorithms": [
    "ecdsa_sha2_nistp256",
    "ssh_ed25519",
    "ssh_rsa",
    "rsa_sha2_256",
    "rsa_sha2_512"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "ecdh_sha2_nistp256"
  "mac_algorithms": [
    "hmac_sha2_512",
    "hmac_sha2_512_etm"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10682372
There must be at least one key exchange algorithm associated with the SSH configuration.
10682373
There must be at least one cipher associated with the SSH configuration.
10682375
Failed to modify SSH key exchange algorithms.
10682378
Failed to modify SSH ciphers.
10682399
Key exchange algorithm not supported in FIPS-enabled mode.
10682400
Failed to modify SSH MAC algorithms.
10682401
MAC algorithm not supported in FIPS-enabled mode.
10682403
There must be at least one MAC algorithm with the SSH configuration.
10682413
Failed to modify maximum authentication retry attempts.
10682418
Cipher not supported in FIPS-enabled mode.
10682420
To modify the SSH configuration of the admin SVM, use the /api/security/ssh REST API.
10682423
There must be at least one host key algorithm associated with the SSH configuration.
10682424
Host key algorithm not supported in FIPS enabled mode.
10682425
Failed to modify Host key algorithms.
10682426
Failed to modify ssh-rsa enabled status for publickey algorithms configuration.
10682428
Cipher not supported in FIPS enabled mode.
10682429
Adding 'diffie_hellman_group16_sha512' or 'diffie_hellman_group18_sha512' to the SSH key exchange algorithms list requires an effective cluster version of ONTAP 9.16.1 or later.
10682430
Failed to modify the login grace time.
string
svm
name
string
uuid
string
svm_ssh_server
ciphers
array[string]
host_key_algorithms
array[string]
boolean
array[string]
login_grace_time
integer
mac_algorithms
array[string]
MAC algorithms.
integer
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
