REST API reference
Create an application Snapshot copy
Creates a Snapshot copy of an application, capturing its state for backup or recovery purposes. This ensures that you can restore the application to a specific point in time if needed.
HTTP method and endpoint
POST /application/applications/{application.uuid}/snapshots
Introduced in
ONTAP 9.6
Required properties
  • name
  • consistency_type - Track whether this snapshot is application or crash consistent.
application.uuid
string
path
True
Application UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
application
application
comment
string
Comment. Valid in POST.
components
array[components]
consistency_type
string
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST.
create_time
string
Creation time
is_partial
boolean
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy.
name
string
The Snapshot copy name. Valid in POST.
svm
svm
uuid
string
The Snapshot copy UUID. Valid in URL.
Example request
  "application": {
    "name": "string",
    "uuid": "string"
  "comment": "string",
  "components": [
      "name": "string",
      "uuid": "string"
  "consistency_type": "string",
  "create_time": "string",
  "name": "string",
  "svm": {
    "name": "string",
    "uuid": "string"
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default, Error
string
application
name
string
Application name
uuid
string
The application UUID. Valid in URL.
components
name
string
Component name
uuid
string
Component UUID
svm
name
string
SVM name
uuid
string
SVM UUID
application_snapshot
application
application
comment
string
components
array[components]
consistency_type
string
create_time
string
Creation time
is_partial
boolean
name
string
svm
svm
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
