Create an application Snapshot copy
Creates a Snapshot copy of an application to preserve its state at a specific point in time. This is useful for backup or recovery scenarios, ensuring that you can restore the application to its previous condition if needed.
HTTP method and endpoint
POST /application/applications/{application.uuid}/snapshots
Introduced in
ONTAP 9.6
Required properties
name
Recommended optional properties
consistency_type- Track whether this snapshot is application or crash consistent.
application.uuid |
string |
path |
True |
Application UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
application |
comment |
string |
Comment. Valid in POST. |
components |
array[components] |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST. |
create_time |
string |
Creation time |
is_partial |
boolean |
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy. |
name |
string |
The Snapshot copy name. Valid in POST. |
svm |
uuid |
string |
The Snapshot copy UUID. Valid in URL. |
Example request
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"components": [
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default, Error
href |
string |
_links
application
name |
string |
Application name |
uuid |
string |
The application UUID. Valid in URL. |
components
name |
string |
Component name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM name |
uuid |
string |
SVM UUID |
application_snapshot
application |
comment |
string |
components |
array[components] |
consistency_type |
string |
create_time |
string |
Creation time |
is_partial |
boolean |
name |
string |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
