Create an application snapshot
Creates a snapshot of an application, capturing its current state for backup or recovery purposes. Use this operation to ensure data consistency and restore capabilities for your applications.
HTTP method and endpoint
POST /application/applications/{application.uuid}/snapshots
Introduced in
ONTAP 9.6
Required properties
name
Recommended optional properties
consistency_type- Track whether this snapshot is application or crash consistent.
application.uuid |
string |
path |
True |
Application UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
application |
comment |
string |
Comment. Valid in POST. |
components |
array[components] |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A snapshot should not be set to 'application consistent' unless the host application is quiesced for the snapshot. Valid in POST. |
create_time |
string |
Creation time |
is_partial |
boolean |
A partial snapshot means that not all volumes in an application component were included in the snapshot. |
name |
string |
The snapshot name. Valid in POST. |
svm |
uuid |
string |
The snapshot UUID. Valid in URL. |
Example request
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"components": [
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default, Error
href |
string |
_links
application
name |
string |
Application name |
uuid |
string |
The application UUID. Valid in URL. |
components
name |
string |
Component name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM name |
uuid |
string |
SVM UUID |
application_snapshot
application |
comment |
string |
components |
array[components] |
consistency_type |
string |
create_time |
string |
Creation time |
is_partial |
boolean |
name |
string |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
