Create a local UNIX user configuration for an SVM
Creates a local UNIX user configuration for a storage virtual machine (SVM) to manage user access and permissions within the SVM environment.
HTTP method and endpoint
POST /name-services/unix-users
Introduced in
ONTAP 9.9
Usage notes
Creates the local UNIX user configuration for an SVM.
Important notes
The default limit for local UNIX users is 32768.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
full_name |
string |
User's full name. |
id |
integer |
UNIX user ID of the specified user. |
name |
string |
UNIX user name to be added to the local database. |
primary_gid |
integer |
Primary group ID to which the user belongs. |
skip_name_validation |
boolean |
Indicates whether or not the validation for the specified UNIX user name is disabled. |
svm |
Example request
"full_name": "Full User Name for user1",
"name": "user1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of UNIX user records. |
records |
array[unix_user] |
"num_records": 1,
"records": [
"name": "user1",
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name |
2621516 |
This operation is only supported on a data SVM |
23724066 |
The specified UNIX user name is too long. Maximum supported length is 64 characters. |
3277051 |
The specified UNIX user name contains invalid characters. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-". |
23724128 |
The specified UNIX user full-name contains the invalid character ':'. |
23724089 |
The specified UNIX user full-name is too long. Maximum supported length is 256 characters. |
23724055 |
Internal error. Failed to create the UNIX user for the SVM. Verify that the cluster is healthy, then try the command again. |
23724090 |
Configuring individual entries is not supported because file-only configuration is enabled. |
3277025 |
Failed to create the UNIX user for the SVM because the system limit has been reached. |
href |
string |
_links
svm
name |
string |
uuid |
string |
unix_user
full_name |
string |
User's full name. |
id |
integer |
name |
string |
primary_gid |
integer |
boolean |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
