REST API reference
Create a local UNIX user configuration for an SVM
Creates a local UNIX user configuration for a storage virtual machine (SVM) to manage user access and permissions within the SVM environment.
HTTP method and endpoint
POST /name-services/unix-users
Introduced in
ONTAP 9.9
Usage notes
Creates the local UNIX user configuration for an SVM.
Important notes
  • The default limit for local UNIX users is 32768.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
full_name
string
User's full name.
id
integer
UNIX user ID of the specified user.
name
string
UNIX user name to be added to the local database.
primary_gid
integer
Primary group ID to which the user belongs.
skip_name_validation
boolean
Indicates whether or not the validation for the specified UNIX user name is disabled.
svm
svm
Example request
  "full_name": "Full User Name for user1",
  "name": "user1",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of UNIX user records.
records
array[unix_user]
  "num_records": 1,
  "records": [
      "name": "user1",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2621706
The specified SVM UUID is incorrect for the specified SVM name
2621516
This operation is only supported on a data SVM
23724066
The specified UNIX user name is too long. Maximum supported length is 64 characters.
3277051
The specified UNIX user name contains invalid characters. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-".
23724128
The specified UNIX user full-name contains the invalid character ':'.
23724089
The specified UNIX user full-name is too long. Maximum supported length is 256 characters.
23724055
Internal error. Failed to create the UNIX user for the SVM. Verify that the cluster is healthy, then try the command again.
23724090
Configuring individual entries is not supported because file-only configuration is enabled.
3277025
Failed to create the UNIX user for the SVM because the system limit has been reached.
string
svm
name
string
uuid
string
unix_user
full_name
string
User's full name.
id
integer
name
string
primary_gid
integer
boolean
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
