Create a local UNIX user configuration for an SVM
POST /name-services/unix-users
Introduced In: 9.9
Creates the local UNIX user configuration for an SVM.
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
full_name  |
string  |
User's full name.  |
id  |
integer  |
UNIX user ID of the specified user.  |
name  |
string  |
UNIX user name to be added to the local database.  |
primary_gid  |
integer  |
Primary group ID to which the user belongs.  |
skip_name_validation  |
boolean  |
Indicates whether or not the validation for the specified UNIX user name is disabled.  |
svm  |
Example request
  "full_name": "string",
  "name": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records  |
integer  |
Number of UNIX user records.  |
records  |
array[unix_user]  |
  "records": [
      "name": "string",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621706  |
The specified SVM UUID is incorrect for the specified SVM name  |
23724066  |
The specified UNIX user name is too long. Maximum supported length is 64 characters.  |
3277051  |
The specified UNIX user name contains invalid characters. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-".  |
23724128  |
The specified UNIX user full-name contains the invalid character ':'.  |
23724089  |
The specified UNIX user full-name is too long. Maximum supported length is 256 characters.  |
23724055  |
Internal error. Failed to create the UNIX user for the SVM. Verify that the cluster is healthy, then try the command again.  |
23724090  |
Configuring individual entries is not supported because file-only configuration is enabled.  |
3277025  |
Failed to create the UNIX user for the SVM because the system limit has been reached.  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
unix_user
full_name  |
string  |
User's full name.  |
id  |
integer  |
name  |
string  |
primary_gid  |
integer  |
boolean  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
