REST API reference
Create a UNIX symbolic link mapping for a CIFS client
Creates a UNIX symbolic link mapping for a CIFS client to integrate UNIX paths with CIFS shares. Use this to facilitate cross-platform file access between UNIX and CIFS environments.
HTTP method and endpoint
POST /protocols/cifs/unix-symlink-mapping
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the CIFS unix-symlink-mapping.
  • unix_path - UNIX path to which the CIFS symlink mapping to be created.
  • target.share - CIFS share name on the destination CIFS server to which the UNIX symbolic link is pointing.
  • target.path - CIFS path on the destination to which the symbolic link maps.
Default property values
  • target.server - Local_NetBIOS_Server_Name
  • locality - local
  • home_directory - false
  • vserver cifs symlink create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
svm
svm
target
cifs_target
unix_path
string
Specifies the UNIX path prefix to be matched for the mapping.
Example request
  "svm": {
    "name": "svm1",
  "target": {
    "locality": "string",
    "path": "/dir1/dir2/",
    "server": "ENGCIFS",
    "share": "ENG_SHARE"
  "unix_path": "/mnt/eng_volume/"
Status: 201, Created
num_records
integer
Number of records
records
array[cifs_symlink_mapping]
  "num_records": 1,
  "records": [
      "svm": {
        "name": "svm1",
      "target": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
655654
Must specify the target CIFS share while creating path mapping entries with localities "local" or "widelink"
655572
The target path contains illegal characters or is too long
655574
The target server contains illegal characters or is too long
655436
If the locality is "local", the target server must be blank or must match the CIFS NetBIOS name for given SVM
655439
The Specified target server is local CIFS server for given SVM but the locality is specified as "widelink"
655546
Failed to create symlink mapping because administrative share cannot be used as target share
655437
Failed to create the symlink mapping with locality "local" because the target share does not exist for specified SVM
655429
UNIX path must begin and end with a "/"
655430
Target path must begin and end with a "/"
655399
Failed to get the CIFS server for specified SVM
string
svm
name
string
uuid
string
cifs_target
home_directory
boolean
Specify if the destination share is a home directory.
locality
string
Specifies whether the CIFS symbolic link is a local link or wide link. The following values are supported:
  • local - Local symbolic link maps only to the same CIFS share.
  • widelink - Wide symbolic link maps to any CIFS share on the network.
path
string
Specifies the CIFS path on the destination to which the symbolic link maps. The final path is generated by concatenating the CIFS server name, the share name, the cifs-path and the remaining path in the symbolic link left after the prefix match. This value is specified by using a UNIX-style path name. The trailing forward slash is required for the full path name to be properly interpreted.
server
string
Specifies the destination CIFS server where the UNIX symbolic link is pointing. This field is mandatory if the locality of the symbolic link is 'widelink'. You can specify the value in any of the following formats:
  • DNS name of the CIFS server.
  • IP address of the CIFS server.
  • NetBIOS name of the CIFS server.
share
string
Specifies the CIFS share name on the destination CIFS server to which the UNIX symbolic link is pointing.
ONTAP allows for both CIFS and NFS access to the same datastore. This datastore can contain symbolic links created by UNIX clients which can point anywhere from the perspective of the UNIX client. To Access such UNIX symlink from CIFS share, we need to create a CIFS symbolic link path mapping from a UNIX symlink and target it as a CIFS path.
svm
svm
target
cifs_target
unix_path
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
