REST API reference
Create a key manager
Creates a key manager to manage encryption keys for securing data within your ONTAP system. You might use this endpoint when you need to configure either an external or onboard key manager for enhanced data protection and encryption management.
HTTP method and endpoint
POST /security/key-managers
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create a key manager.
  • external.client_certificate - Client certificate. Required only when creating an external key manager.
  • external.server_ca_certificates - Server CA certificates. Required only when creating an external key manager.
  • external.servers.server - Primary Key servers. Required only when creating an external key manager.
  • onboard.passphrase - Cluster-wide passphrase. Required only when creating an Onboard Key Manager.
  • synchronize - Synchronizes missing onboard keys on any node in the cluster. Required only when creating an Onboard Key Manager at the partner site of a MetroCluster configuration.
  • security key-manager external enable
  • security key-manager onboard enable
  • security key-manager onboard sync
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
external
external
Configures external key management
onboard
onboard
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.
policy
string
Security policy associated with the key manager. This value is currently ignored if specified for the onboard key manager.
svm
svm
uuid
string
Example request
  "external": {
    "client_certificate": {
      "name": "string",
    "server_ca_certificates": [
        "name": "string",
    "servers": [
        "secondary_key_servers": "secondary1.com, 10.2.3.4",
        "server": "keyserver1.com:5698",
        "timeout": 60,
        "username": "admin"
  "is_default_data_at_rest_encryption_disabled": true,
  "onboard": {
    "existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
    "key_backup": "'--------------------------BEGIN BACKUP-------------------------- TmV0QXBwIEtleSBCbG9iAAEAAAAEAAAAcAEAAAAAAAAxBFWWAAAAACEAAAAAAAAA QAAAAAAAAABzDyyVAAAAALI5Jsjvy6gUxnT78KoDKXHYb6sSeraM00quOULY6BeV n6dMFxuErCD1lbERaOQZSuaYy1p8oQHtTEfGMLZM4TYiAAAAAAAAACgAAAAAAAAA 3WTh7gAAAAAAAAAAAAAAAAIAAAAAAAgAZJEIWvdeHr5RCAvHGclo+wAAAAAAAAAA IgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAAAAAAAAAAAAACAAAAAAAJAGr3tJA/LRzU QRHwv+1aWvAAAAAAAAAAACQAAAAAAAAAgAAAAAAAAADV1Vd/AAAAAMFM9Q229Bhp mDaTSdqku5DCd8wG+fOZSr4bx4JT5WHvV/r5gJnXDQQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOZXRBcHAgS2V5IEJsb2IA AQAAAAMAAAAYAQAAAAAAALgePkcAAAAAIgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAA AAAAAAAAAAACAAAAAAAJAGr3tJA/LRzUQRHwv+1aWvAAAAAAAAAAACIAAAAAAAAA KAAAAAAAAACIlCHZAAAAAAAAAAAAAAAAAgAAAAAAAQCafcabsxRXMM7gxhLRrzxh AAAAAAAAAAAkAAAAAAAAAIAAAAAAAAAA2JjQBQAAAACt4IqXcNpVggahl0axLsN4 yQjnNVKWY7mANB29O42hI7b70DTGCTaVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAE5ldEFwcCBLZXkgQmxvYgABAAAAAwAAABgBAAAAAAAA 7sbaoQAAAAAiAAAAAAAAACgAAAAAAAAAQ5NxHQAAAAAAAAAAAAAAAAIAAAAAAAkA ave0kD8tHNRBEfC/7Vpa8AAAAAAAAAAAIgAAAAAAAAAoAAAAAAAAALOHfWkAAAAA AAAAAAAAAAACAAAAAAABAMoI9UxrHOGthQm/CB+EHdAAAAAAAAAAACQAAAAAAAAA gAAAAAAAAACnMmUtAAAAAGVk8AtPzENFgsGdsFvnmucmYrlQCsFew0HDSFKaZqK6 W8IEVzBAhPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ---------------------------END BACKUP---------------------------'",
    "passphrase": "The cluster password of length 32-256 ASCII characters."
  "policy": "string",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: 201, Created
num_records
integer
Number of records
records
array[security_key_manager]
  "num_records": 1,
  "records": [
      "external": {
          "name": "string",
            "name": "string",
        "servers": [
            "timeout": 60,
            "username": "admin"
      "onboard": {
      "policy": "string",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
65536038
A maximum of 4 active primary key servers are allowed.
65536214
Failed to generate cluster key encryption key.
65536216
Failed to add cluster key encryption key.
65536310
Failed to setup the Onboard Key Manager because the MetroCluster peer is unhealthy.
65536341
65536508
The platform does not support data at rest encryption.
65536821
The certificate is not installed.
65536823
The SVM has key manager already configured.
65536824
Multitenant key management is not supported in MetroCluster configurations.
65536834
Failed to get existing key-server details for the SVM.
65536852
Failed to query supported KMIP protocol versions.
65536870
Key management servers already configured.
65536871
Duplicate key management servers exist.
65536876
External key management requires client and server CA certificates installed and with one or more key servers provided.
65536878
External key management cannot be configured as one or more volume encryption keys of the SVM are stored in cluster key management server.
65536895
External key manager cannot be configured because this cluster is part of a MetroCluster configuration and the partner site of this MetroCluster configuration has Onboard Key Manager configured.
65536900
The Onboard Key Manager cannot be configured because this cluster is part of a MetroCluster configuration and the partner site has the external key manager configured.
65536903
The Onboard Key Manager has failed to configure on some nodes in the cluster. Use the CLI to sync the Onboard Key Manager configuration on failed nodes.
65536906
The Onboard Key Manager has already been configured at the partner site. Use the CLI to sync the Onboard Key Manager with the same passphrase.
65536913
The Onboard Key Manager is already configured. Use the CLI to sync any nodes with the Onboard Key Manager configuration.
65536916
The Onboard Key Manager is only supported for an admin SVM.
65536920
The Onboard Key Manager passphrase length is incorrect.
65537240
The Onboard Key Manager passphrase must be provided when performing a POST/synchronize operation.
65537241
The Onboard Key Manager existing_passphrase must not be provided when performing a POST/synchronize operation.
65537244
Unable to sync/create Onboard Key Manager on the local cluster; Onboard Key Manager is already configured on the cluster.
65537245
Unable to sync/create Onboard Key Manager on the local cluster; Onboard Key Manager is not configured on the partner cluster.
65537246
Unable to sync/create Onboard Key Manager on local cluster. This cluster is not part of a MetroCluster configuration.
65538111
The key manager policy is invalid.
65538120
The key manager policy is not supported on the admin SVM.
65539216
The Admin SVM has a key manager already configured.
66060338
Failed to establish secure connection for a key management server due to incorrect server_ca certificates.
66060339
Failed to establish secure connection for a key management server due to incorrect client certificates.
66060340
Failed to establish secure connection for a key management server due to Cryptsoft error.
string
client_certificate
Client certificate (name and UUID)
name
string
Certificate name
uuid
string
Certificate UUID
Security certificate object reference
name
string
Certificate name
uuid
string
Certificate UUID
node
name
string
uuid
string
key_server_state
The connectivity state of the key server for a specific node.
node
node
state
string
Key server connectivity state
connectivity
This property contains the key server connectivity state of all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability
boolean
Set to true when key server connectivity state is available on all nodes of the cluster.
node_states
array[key_server_state]
An array of key server connectivity states for each node.
key_server_readcreate
string
A comma delimited string of the secondary key servers associated with the primary key server.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
Username credentials for connecting with the key server.
external
client_certificate
client_certificate
array[server_ca_certificates]
The array of certificates that are common for all the keyservers per SVM.
servers
array[key_server_readcreate]
The set of external key servers.
onboard
enabled
boolean
Is the onboard key manager enabled?
existing_passphrase
string
The cluster-wide passphrase. This is not audited.
key_backup
string
Backup of the onboard key manager's key hierarchy. It is required to save this backup after configuring the onboard key manager to help in the recovery of the cluster in case of catastrophic failures.
passphrase
string
synchronize
boolean
Synchronizes missing onboard keys on any node in the cluster. If a node is added to a cluster that has onboard key management configured, the synchronize operation needs to be performed in a PATCH operation. In a MetroCluster configuration, if onboard key management is enabled on one site, then the synchronize operation needs to be run as a POST operation on the remote site providing the same passphrase.
status
Optional status information on the current state of the key manager indicating if it is fully setup or requires more action.
code
integer
Code corresponding to the status message. Returns 0 if the setup is complete. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
message
string
Current state of the key manager indicating any additional steps to perform to finish the setup. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
name
string
uuid
string
volume_encryption
Indicates whether volume encryption is supported in the cluster.
code
integer
Code corresponding to the status message. Returns a 0 if volume encryption is supported in all nodes of the cluster.
message
string
Reason for not supporting volume encryption.
supported
boolean
Set to true when volume encryption support is available on all nodes of the cluster.
external
external
onboard
onboard
policy
string
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
